Need help using dd1
so when getting the max volume everything should be flat on headunit (bass,treble,mids)
also on the amp should it be switched to flat or HPF and what should my HPF freq be on after setting gains and getting max undistorted volume
i just feel like im doing something wrong:/
2002 Mustang GT Procharged
Procharger P1SC Supercharger, 8psi
Procharger Intercooler, Headers,
Borla Off Road X-Pipe Exhaust, Mass Airflow
Upgraded Fuel Injectors
SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
I think this is the 3rd post asking the same thing. Lol
2003 Tahoe
dc 7.5k
dc level 5 15's (3)
MMats 341's
xs power batts
lots of sky high cable
dual alts(came off the sky-high gmc and don't know who made them)
ipad in center console
vu-din in center console
all being ripped out and being sold
i just feel like im doing something completely wrong lol :/
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Stick with on thread and people will see it. Or you can reply to your own and bump it. Patience is all.
2003 Tahoe
dc 7.5k
dc level 5 15's (3)
MMats 341's
xs power batts
You asked at 8am, you can't expect your question to be answered in minutes. The people on here that have the knowledge are normal people who have everyday lives. Everything on your amps and head unit should be set to flat, then afterwards adjust to what the other guy said in your other post.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
does this go also for getting the max undistorted volume of headunit??
Edited by Skax
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Any adjusting you do that involves your dd -1, you must set am your settings to flat prior to use. Then after set them back to where you liked them.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
so for headunit also hpf all way down lpf all way up switch on flat?
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
i guess the only think im missing is these 2 questions
and also how do u set the actually headunit eq's to flat?
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Anything and everything that effects the source of your signal. All crossovers set to off if possible. If not do what you said about the filters for hpf and lpf. Bass boost always off, any eq setting, set to 0 flat or off.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • Who's Online   1 Member, 0 Anonymous, 1336 Guests (See full list)
