fuse holder
ok here is what i came up with to make do with what i have. i took the fuse holder i got from sky high car audio on the left. then drilled it out with a 9/16 drill bit to fit the zero gauge on the right.
now the reason i did this. is because i felt that the zero gauge was not fitting correctly in the one on the left. also, i am using sky high car audio wire. i have both the first generation wire and second generation wire. so the new wire is a little bit bigger that the older wire.
  • Who's Online   0 Members, 0 Anonymous, 3129 Guests (See full list)
