Im looking to spend 2-3k, I just bought a 2006 expedition and im planning on getting a build to do 150+. I had a grand marquis walled off with 4 sa15's, doing a 149. I want to double my power, get a 4-5k amp and either 4 15s or 2 18s. what do you guys suggest? theres not a lot of expedition builds >.<
as for electrical im planning on welding a alt bracket for another alt and get around 350 amps, probly 4 dekas in the back and the biggest i can fit up front?
We'll I say you need more monies. 2 high out put alts will be 700-1000 on its own. Then you will need a 5k amp that will cost at least 1k-1500 depending on brand. Then batteries then subs then wiring,fusing,misc,. Then build the box about another 200 or so.
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
What are you keeping from your current build
And what dose it consist of
Your goal is 150 but @30hz, 50hz is somewhere Inbetween
With 3k
1off ns1
4off X15d2
At 4ohm final
Then when the funds are there for more batt and alt, wire to 1ohm final
  • Who's Online   0 Members, 0 Anonymous, 506 Guests (See full list)
