Alternator charging way too high
2 battery's! 1 up front one in the cab! Yellow top up front and kinetik 2400 in back both a year old maybe less? When I shut the truck off they rest at 13.5 and after while slowly fall too 12.9 sometimes an even 13
Put another battery in an i can almost bet your issue will be gone or nkt nearly as bad.
There isnt enough battery to soak up the spikes.
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Really??? I'm not douting you but has this been an issue with other people!???!! Should I be getting another kinetik 2400 or some huge xs battery for $500 I really want to stop these spikes it's annoying!
I thought you sorted the issue by increasing belt tension?
I ended up with three 120+ah batteries, and a 50ah battery in mine, and still had the amps shut down due to the voltage spikes...
happend to a couple people i know.
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
Atl*
There is no Y in alternator ;)
Bassically your dropping voltage, then the alts say " i need to charge higher" And then it does so, but once that bass not stops The voltage will spike really quick because theres not enough battery to absorb the spike.
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
  • Who's Online   0 Members, 0 Anonymous, 3448 Guests (See full list)
