Picking a setup
quincyj34
I am building a box with about 2.5 cu.but I can't decide what to put in it.
I'm thinking either 2 sa-10s ported, or 1 sa-12 ported, or 2 E-12s or even wait for the x-12 and put it in a ported box . Just wanted to know what you guys think. This will be in a truck and I listen to mostly rap, hip-hop, and dubstep. The wattage will be about the with either one which will be about 1k watts.
Single cab? Extended cab? Crew cab? What's your maximum budget? And considering you like bass heavy music, your looking for a ported enclosure. And that means your going to be pressed for space.. Way to many variables to say which would suit you the best..
Also, never put the carriage before the horse (or is it mis? *drum beat*). The first thing you do is make sure electrical can handle. Then you find what sub. Then amp. Then box.
Sheena = pedobear
My electrical will be upgraded as well. Im have a hard time deciding what setup i would like to go with. My truck is an ext. Cab and i found out Latley ive been thinking of two E-12 in a 3.0ft^3 ported and tuned at 33-35hz or one sa-12 in the 2.5ft^3 ported and tuned at 35. As far as the amp im looking at a hifonics 1600w but i am open for suggestions
You removing the rear seat? I'm assuming so with a box that big. But you def need to have your equipment decided on before worrying much about the box.
2 - Sundown SA 8V2 | CT Sounds 1400.1 | Pioneer DEH-X8500BS | 4/0 Big 3
  • Who's Online   0 Members, 0 Anonymous, 3178 Guests (See full list)
