Skax Posted February 5, 2014 Report Posted February 5, 2014 ok i recently bought 3 250 amp fuses 1 under hood 1 before distribution block and 1 mini anl inside distribution block and im running 0awg cca wire would this be fine for my 2500bdcp and my tma440.4 or do i need to order 3 more 300 amp fuses? 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
Kyblack76 Posted February 5, 2014 Report Posted February 5, 2014 Why do you think you need half a dozen 300 amp fuses? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold
Skax Posted February 5, 2014 Author Report Posted February 5, 2014 Why do you think you need half a dozen 300 amp fuses? i was told to put 1 under the hood 1 before the distribution block and a 50 and 200 amp fuse inside the distribution block would this be okay for the 2500bdcp on 0awg cca? 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
Skax Posted February 5, 2014 Author Report Posted February 5, 2014 bumppppp 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
Pauly1987 Posted February 5, 2014 Report Posted February 5, 2014 Would you not fuse for the size of wire itself? usually a 0gage wire is safe to carry 300amps of current thus meaning you would use a 300 amp fuse!! Don't know about distribution blocks so won't give you any info on that maybe someone else will chime in on that! I use a 300amp fuse on all my 0 gage wire ran in the truck!
