Nightshade V3s
DollarBill1
I was going to run two 18 ZV4's walled in a crew cab Chevy but the Nightshade V3's are now available. How much better would the Nightshades be if I ran on a NS1 V2.
2009 Chevy 2500HD Crew Cab
Current Set up -
Headunit - JVC 6100BT
Mids/Highs - Sundown SA-6.5 CS x2
- 4 Crescendo pwx6.5's
- 2 Crescendo ft1's
Mids/Highs amps - 2 Sundown SAX100.4 V2
Sub amp - NS-1 V2
Alts - 2 Singer 320a 6 Phase
2 XS D4800 under the hood
2 XS D3100's in back
2 Sundown Team 18's walled
Ib4tl
Depends on what ohm load you plane to run
But if you can afford the ns go with that as you will never be left wanting
Just don't expect them to peek high
Just remember both thoes sub will take the ns1 at 1ohm on there own but the ns can do it at 0.5
So if you get the right coil config when $$$ is there you'll be able to strap that ns1 and really liven up the ns subs
I already have the NS1 and was planning on getting 1ohm subs so I can run 1ohm.
Current Set up -
- 2 Crescendo ft1's
Sub amp - NS-1 V2
  • Who's Online   0 Members, 0 Anonymous, 2855 Guests (See full list)
