2- 15" Fi BL sub enclosure HELP.
jake297
Designing a box takes a lot of time and work. Look around at some build logs to get ideas. Then get yourself a pencil and lay it all down on some graphing paper.
My box is built to specs for BL 12's, link is in my sig.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
-Thanks guys for the input appreciate it.
***No I haven't built the box yet .those were just my maximum dimensions for a box that would it in my truck . I like joes design but I'm looking for some other opinions/ideas
Looking for a slot port design see how that differs from Joes L port design at 10cuft
the only things you can vary from a slot port box is the size of the box and the dimensions of the port.
you want 10 cubes, okay, aroudn 140sqin of port. play with port dimensions til you get that and the tuning you want.
you literally will not know which box design will be best without building every single one and testing them individually. just because "that one" looks nicer, doesnt necessarily mean it will perform better.
@clean Sierra - you wouldn't be able to have a divider in that design because then you would a seperate port for each sub
not necessarily.
@ kranny. thanks man, I don't have any o the computer software and I am unable to download it . So that's why I'm looking for some help.-(like what joe did with Torres and came up with the cut sheet)
I was saying a divider to completely separate a section. I'm not taking about individual chambers for the subs, but one common one. I was only saying using a divider to completely take part of the airspace out of the equation.
Joe's design was fine. I could design one bit it wouldn't be much different than Joe's
  • Who's Online   0 Members, 0 Anonymous, 3894 Guests (See full list)
