2- 15" Fi BL sub enclosure HELP.
jake297
All my electrical is good also...big 3 kinetic 2000 in the back with a yellow top up front.
* just need port specs with box dimension specs . My maximum box size can be : 24"height x 58" wide x 24" depth. That is around 16cuft. I was told that is to much space for my subs...so if anyone can come up with a smaller box?
Here is what my box specs are.
Of course this is in a car and sounds perfect for what i want. I can play 25Hz-40Hz and it peaks at 33Hz. My BL is powered by a SQ2200.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
@BIGmaniac- thanks man.gabe me a reference on my pot area . Thanks.
-I'm still looking for a good enclosure for 2 fi BLs 15s in a 10-15cuft box ..trying to come up with something...just need help://
What do you mean a pretty back behind the subs? Port between them doesn't meter or sound best to the ear in an extended cab truck. Typically subs up, port up to the drivers or passenger side is loudest. Some guys also have good luck with port up and subs forward.
  • Who's Online   0 Members, 0 Anonymous, 2631 Guests (See full list)
