GueroZ28 Posted February 9, 2014 Report Posted February 9, 2014 I want to buy 2 of the SoundQubed HDS200 12" 600wrms. The amp is pretty pricey but i do have a db drive 1050 monoblock.. so if i wire them at 1ohm it should push the subs with no problem right?
bbeljefe Posted February 9, 2014 Report Posted February 9, 2014 It'll do fine. Facebook: facebook.com/audioanarchyllc Instagram: audioanarchyllc Youtube: youtube.com/bbeljefe
Guest Posted February 9, 2014 Report Posted February 9, 2014 amp has two 35 amp fuses. will do like 800 watts. you'll be underpowering the speakers a bit. edit: i found the amp for $158 on amazon. thats not pricey
GueroZ28 Posted February 9, 2014 Author Report Posted February 9, 2014 amp has two 35 amp fuses. will do like 800 watts. you'll be underpowering the speakers a bit. edit: i found the amp for $158 on amazon. thats not pricey Which amp is that? But it wont damage them or anything right
bbeljefe Posted February 9, 2014 Report Posted February 9, 2014 No, it won't damage them. Facebook: facebook.com/audioanarchyllc Instagram: audioanarchyllc Youtube: youtube.com/bbeljefe
CodyLucente Posted February 9, 2014 Report Posted February 9, 2014 As long as you don't crank up the gain in an attempt to put out more power then you will be fine. Those are some of the best subs you can buy so that's about the only way you can fry them with that amp. But it will pound, not comp ready but still pound How is DB drive? i know there a newer product but it looks sweet, i have been curious about their quality? edit* I am about to buy a pair of 312's or 212's from soundqubed (AQ) for my CT sounds 1200 similar setup to your just a little more powerful amp and a custom box. Subs= SoundQubed HDC3.112 Amps= Audio Technix1200.1, Sony XM4x40 & Clarion XC1410 Rear= Pioneer 6"x9" coaxial Front= Polk 6 1/4 componants Trunk Lid= Pioneer 6 1/4 coaxil Battery= Optima Yellow-top (front) Shrunken 35AH Wire= 0/2 AWG welding Cable! Alternator= 125amps Extra= Continuous duty solenoid
Guest Posted February 9, 2014 Report Posted February 9, 2014 amp has two 35 amp fuses. will do like 800 watts. you'll be underpowering the speakers a bit. edit: i found the amp for $158 on amazon. thats not pricey Which amp is that? But it wont damage them or anything right yours.... no it wont damage anything. unless you have improper settings on the amp/headunit and clip/distort the fuck out of the woofers.
Guest Posted February 9, 2014 Report Posted February 9, 2014 As long as you don't crank up the gain in an attempt to put out more power then you will be fine. Those are some of the best subs you can buy so that's about the only way you can fry them with that amp. But it will pound, not comp ready but still pound How is DB drive? i know there a newer product but it looks sweet, i have been curious about their quality? edit* I am about to buy a pair of 312's or 212's from soundqubed (AQ) for my CT sounds 1200 similar setup to your just a little more powerful amp and a custom box. i've heard their only good amps are the a7 series. no idea if thats fact or not, but yeah.
hazestorm23 Posted February 9, 2014 Report Posted February 9, 2014 amp has two 35 amp fuses. will do like 800 watts. you'll be underpowering the speakers a bit. edit: i found the amp for $158 on amazon. thats not pricey is that the db drive okur amps? I always wondered about those
CodyLucente Posted February 9, 2014 Report Posted February 9, 2014 A3-1050.1D http://dbdrive.net/product/a3-1050-1d and that amp haS 2x40A fuses so 80A X 12v = 960Watts 80A X 14V = 1120watts this is the MAXIMUM power output and i am not certain if this brand does rated so i would say like kranny said apx 800-850watts rms (i have learnt the hard way every time you don't follow his advice it bites you in the ass) 2^1x800 = 29v. So set your gain on a multi-meter to 29v if you go to your shop you may be able to squeeze a couple extra watts out. Subs= SoundQubed HDC3.112 Amps= Audio Technix1200.1, Sony XM4x40 & Clarion XC1410 Rear= Pioneer 6"x9" coaxial Front= Polk 6 1/4 componants Trunk Lid= Pioneer 6 1/4 coaxil Battery= Optima Yellow-top (front) Shrunken 35AH Wire= 0/2 AWG welding Cable! Alternator= 125amps Extra= Continuous duty solenoid
