Skax Posted February 10, 2014 Report Posted February 10, 2014 was wondering how to go about extending the wires to hook them into the headunit and where to hook them in at and what to use to extend the wire? thanks 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
k3n12ock Posted February 10, 2014 Report Posted February 10, 2014 Can use primary wire or even speaker wire. As for where, put it wherever it looks nice. 05 xB - (2) EVIL 18s - (2) BC3500s - NO WALL Channel 1: http://www.youtube.com/k3n12ock Channel 2: http://www.youtube.com/MrK3n12ock2
youngbass98 Posted February 10, 2014 Report Posted February 10, 2014 I just used some spare 16 gauge wire and hooked it to my amp, but in your case just splice the power wire and use one of those twist cap connectors or something 06 monte carlo 2 12 rockford p3s soundstream rubicon 2500 crescendo audio mezzo 6.5 ct sounds 125.4 execution audio and shca wiring 2 xs d3400 on stock alt
Skax Posted February 10, 2014 Author Report Posted February 10, 2014 I just used some spare 16 gauge wire and hooked it to my amp, but in your case just splice the power wire and use one of those twist cap connectors or something is it possible to just run a shorter run and hook it up to the headunit? 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
youngbass98 Posted February 10, 2014 Report Posted February 10, 2014 Ya like I said splice the power wire and connect the wire from the volt meter to it, the other wire on the volt meter you just ground it 06 monte carlo 2 12 rockford p3s soundstream rubicon 2500 crescendo audio mezzo 6.5 ct sounds 125.4 execution audio and shca wiring 2 xs d3400 on stock alt
Skax Posted February 10, 2014 Author Report Posted February 10, 2014 Ya like I said splice the power wire and connect the wire from the volt meter to it, the other wire on the volt meter you just ground it so red to power blue to remote and black to ground in headunit and ill be good to go? what size speaker wire would be ok to extend the 3 wires? 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
newls1 Posted February 10, 2014 Report Posted February 10, 2014 make sure you place this gauge in a EASY to REMOVE location for easy access to replace it. Do not forget to set the gauge with a real volt meter as well, as it does not come even close to accurate out of the box (or atleast the 64 i went thru didnt) I love my staffie So anti FACEBOOK it isn't even funny
youngbass98 Posted February 10, 2014 Report Posted February 10, 2014 Ya pretty much, and really any size I used 16 06 monte carlo 2 12 rockford p3s soundstream rubicon 2500 crescendo audio mezzo 6.5 ct sounds 125.4 execution audio and shca wiring 2 xs d3400 on stock alt
Skax Posted February 10, 2014 Author Report Posted February 10, 2014 Ya pretty much, and really any size I used 16 ok will do i was just ganna mount it in the dash right beside my bass knob 2002 Mustang GT Procharged Procharger P1SC Supercharger, 8psi Procharger Intercooler, Headers, Borla Off Road X-Pipe Exhaust, Mass Airflow Upgraded Fuel Injectors SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood -Front 275/40ZR17 -Rear 315/35ZR17 5.0 Short Shifter 3.55 Gears
