3 opti1233d trunk wall?
Hammer Knock
should i stick with 2. or go to 3? i have 3 but not using right now. also should i just seal the trunk on the inside a bit. because im looking for trunk room. with this system :P
if the car doesn't stall, you have enough voltage.
DEH-6400BT
BC3500D on 2 x 12" Lanzar Opti1233d
QBOMB 4.5cu
1/0 awg, Lanzar AMPKIT0
Singer 275 + LCAKT50DBL
you want trunk room with 3 12's? lol.
stick with 2 12's sealed off firing forward.
make a 4th order blow thru into cab. shit would be nasty.. plexi box covered in led lol
:domodance: :domodance::morepower1:New Build in the Making :morepower1: :domodance: :domodance:
1999 Infiniti I30 Limited
if you break a rule and argue with n8 your going to get banned. suspended if your lucky.
port would face up to the window. no?
DEH-6400BT
QBOMB 4.5cu
them? the subs yah. but the port? probably will only be 1 port. rectangle if possible.
DEH-6400BT
QBOMB 4.5cu
  • Who's Online   0 Members, 0 Anonymous, 6242 Guests (See full list)
