Quarter Wave / T-Line tutorial-UPDATED
Forevrbumpn
5:1 what?
Hammerdown... 1%
ratio of what? The wave length? Then you're not using 1/4 wave theory anymore and are going to have poor results with anything other than a closing taper or stepped chambers.
Hammerdown... 1%
Is it okay to make a T-line with 20 hz tuned and putting a sub with a FS of 30 hz ???
It means using these parameters.
1130 / 20(HZ) = 56.5 ft
56.5 / 4 = 14.125 ft long.
Sd = 1210 cm2 = 187.5 sq inch port area.
I am doing right ????
LBM - Yes, you can tune to whatever frequency you want.
87 regal, You taper like a horn. Either opening slowly from beginning to end, or closing slowly from beginning to end. What ratio are you talking about if its not tapering or frequency?
Hammerdown... 1%
Tapering of the cross sectional area. I looks like most people in here are doing constant area t-lines. Usually more wood to cut, and can be a pain in the ass to fit the magnet.
turn the sub mount 45 degrees to the right for added fun :)
Hammerdown... 1%
  • Who's Online   0 Members, 0 Anonymous, 1347 Guests (See full list)
