Quarter Wave / T-Line tutorial-UPDATED
Forevrbumpn
you sound like me LSN... lol.... at one point I had about 30-40subwoofers in my garage ranging from 6"- 15" Well, the number was alot higher, I had 2 boxes of 60- 6.25" subwoofers, then the rest were the 8s, 10s, 12s, 15s, and other 6"s... I have dwindeled down to about 15-20 subs, and about 30 oddball misc mids/coaxes/tweeters
hey Forevrbumpn.  i biult 2nd tline box, sounds great. im wondering max rms power for 1/4 tline box and 1 sub?
i have this q. because lots of tline boxes use small subs and low wattage, so im thinking that there would be max amp rms power where to much would be waste.
I NEED HELP!!!< haha, alright tonight i am designing  a 1/4 tline for my rodeo... i have lots of space in the back and what to give this design a shot... i have 2 tens i will be puting into it.. so far using your equations i have figured i need a port of 120 sq in. and it has to be 8.75 ft. long... what i am wondering is, does th port have to take up the whole width of the box muxh like the one you built, or can it be sectioned off into a different "shape" but still the proper dimensions.....also, does each mid section of the box have to be the same... my sub is approx. 6 in mounting depth....sop basically if i build my box to take up the back of my truck i would have a port 40'' by 2''.... and then 2'' to each mid section i would have no room to mount a sub, let alone 2.... either i am making this way harder then it is or i have not caught the right sentence that explains this question, any help asap would be apprecited!!!
This is one of the greatest things i have read in a long time. i reall appreciate you taking the time to do this tutorial. but i have a question for you or anyone who can answer.... if a driver is suited for a TL but its Fs is low so it needs a really long length and you want to shorten it by using polyfill, which you stated can be done, how much does that shorten the length? is there a percentage? for example, if full length should be 12ft but polyfill reduces length by 25% you can make it 9 feet and it will have the same tune? thanks in advance, Trevor
"And you CAN go short on a tline, and stuff it with poly fill, or line the walls with 1" or 2" poly fill, and you can similate a line about 50% longer."
as i read through the second time i realized you did put a percentage. is this a guess or a fact? i cant believe it would change 50%. so a DD 2512 could go from a 6.6 ft length down to a 3.3 ft length with an estimated Sd of 88 and Fs of 26?
one more thing... how do you measure the length? i made something on paint but i dont knwo how to post it... but in your paint document... do you measure all the red? or do you just measure to where they intersect and then change 90 degrees, which would be the measurement right down the middle... I've seen someone add up all the port wall segments and total that to their total length needed which seems too short compared to what you do. could you please explain? or if you ahve all the measurments of the box you just did that would be great!
Thank you so much for this tutorial! I always wanted to try a t-line, and it all seemed too confusing for a relative novice (shit im only 18) to try.  I'm thinking of building one for my friend as a guinea pig.  He runs a type r 12 though, with a QTS of .47, is that too high for a t-line?
Can't wait to try it out! Thanks again!
A couple links to some box builds:
Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI,
Mini-Bump, Hummer H2, Ford F-150
My own car builds (current setup --- under construction):
Overall Thread, Kickpods, Dash, Back Doors
Subwoofer Wall
Question 2: Would this setup even be worth the space taken up?  Going from 2.5 cu ft to around 7 is a big jump.  (That figure is just an estimate, but the overall area is between 6 and 8)
Subwoofer Wall
k, question 3.  When stuffing with polyfill, how packed am i going? you said loosely, but I just want to make sure so my tuning's not off.  I'd rather not give up 14 feet if i can restrict it to 7.  Should I just pack it tight and assume its 50% reduction in length?
Thanks again!
Subwoofer Wall
General rule-of-thumb w/ poyfilling a "traditional" box is 1lb per cubic foot.
I'd go out on a limb and assume the same here unless anyone has info suggesting a diff percentage/mix.
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
  • Who's Online   1 Member, 0 Anonymous, 1101 Guests (See full list)
