XS Power
So i got a used d3100. The negative terminal has a couple stripped threads in it (exactly where they need to be to tighten down my toolmaker terminals)
Has anyone ever rethreaded these?
Any suggestions on maybe raising the TM terminals higher and maybe try to use threads that are not damaged? (I guess that would mean a shorter bolt)
What about something like this
http://4xspower.com/shop/terminals/589/
Anyone know where i could get something like that? ^
Im just trying not to lose my ass on scraping this battery just to buy a new d3100 (which i should have done in the first place) . I got it resting 12.9 after some training.
This is the couple year old d3100 with the MAX amps rainy for 3200 (not 5000).. currently m7 bolts fit in it (not the m6's like I've seen everywhere else)
edit: i know there are only a few stripped threads because once i get past them it tightens down nicely. But i guess 3-4 lugs stacked or the height of my distro blocks are exactly where i am ending up. And once i try to tighten them down and fail (starts spinning).. i pull everything out and i can see 1 or 2 thread shavings at the bottom which I've cleaned up.
Any thoughts or suggestions?
Edited by Swordlordboy1234
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
Helicoil?
Ask XS if you can use a helicoil.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
didn't know about those... Researching now..
Anyone else?
btw thanks for that suggestion bro :)
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
run a tap through it to try to clean up the threads, if it doesnt work re-tap it a size bigger.
would contact xs and see if that is okay first though.
98 Mustang GT
Singer 320
2 12" Incriminator Death Penalties
1 SAZ-2500dv2
2 D3100,1 D3400
2 Crescendo CZ-65
SAX-100.2
Door panels by Diablo Kustomz
messaged nathan on here a few days ago. No reply yet.
Thinking of calling the office if he doesn't reply.
Anyone know the hours off hand? Assuming m-f 9-5?
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
Yeah i was thinking a variation of bolt size might be worth a try. Just debating if longer or shorter is best. The threads that are gone are only like 1/4 off the bottom.
Now I'm deciding if maybe a little .75 or .5 inch long bolt is able to work.
Learned my "Lets buy used to save money" lesson for the 5th or 6th time now.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
Ah just JB weld a terminal on her bud...
But seriously, helicoils are really good. If the threads are still pretty good a helicoil will hold just as strong as the original threads.
I used a helicoil on my sled's primary clutch main spring cup...holds a 300lb spring @ 8600rpm.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
Lesson- inspect fully before buying
Lesson - still inspect even though you are friends with the person.
The Helicoil DIY i found online was i guess the worse case. He drilled the threads clean with a drill.. then used his kit to make brand new threads and then make sure the bolt threads were perfect... then tighten down.
I found a $40 kit on harbor freight... Anyone got any advise on this one? After a quick stop at auto zone for some washers and bolt combos I've pretty much determined that its gonna need to be re done. Im no professional but I'm pretty sure if something strips threads the moment its more then "finger" tight then something isn't right.
http://www.harborfreight.com/hand-tools/tap-die/60-piece-sae-metric-tap-and-die-set-35407.html
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
