AGuyWithAJeep Posted February 18, 2014 Report Posted February 18, 2014 I plan on putting 2 Fi BL 15's in a 2002 Grand Prix. So far I have planned to put in a box that is 16' High, 36" Wide and 34" Deep. Totals out at 9.41 Cu Ft without displacement of anything. I planned on using aero ports, i want the box to be tuned at 31 or 32 hertz. I'm new to the whole aero ports thing, but what i got was i would need 3, 6" Flared Aero ports that are 21.5 inches long (each). Does this sound right or did i completely do this wrong? Like i said i am new to this and have little idea on how to do this. Thanks!!
agf144 Posted February 19, 2014 Report Posted February 19, 2014 there is no way in hell that will fit trust me i own a grand prix. it is possible to fit 2 15 in the trunk ported but that will use alot of the trunk and will have to be built in the trunk... and 9 cubes is a bit to much try 7.5-8 net. Chick took 3 shots of Jager, and then, pissed in my mouth.. oh.. wait.. naw.. that wasnt weird.. He probably tearin dat ass up every night. Reason for "insomnia" Ain't sleeping cause he's like a horny hamster on coke. 2000 grand prix gtp: SOLD My Home Theater Build (working progress) 2002 accord coupe subs: 2 soundqubed hds300 12s 4'1" towers tuned to 29hz sub: AQ hdc3 12 Amp: pioneer gm9061 amp: poineer gm9601 headunit: kenwood kdc 255u mids: SQ pro mids midbass: polk db 8s highs: stock mids/highs: shitty off brand
ChevyBoy95 Posted February 19, 2014 Report Posted February 19, 2014 you pretty much spot on, comes out to about 7.9 cubes, with 32hz tuning. I say build it if you can fit it. edit: this was 1 layer of 3/4 inch MDF all around. You could add some bracing and be fine. Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/
agf144 Posted February 19, 2014 Report Posted February 19, 2014 so then im assuming subs up port back then? or u could utilize the space after the wheel wells and make the face of the box wider to fit the ports because not everything will fit on the face as it is. and add a 2nd baffle which should compensate for the space gained and add strength. Chick took 3 shots of Jager, and then, pissed in my mouth.. oh.. wait.. naw.. that wasnt weird.. He probably tearin dat ass up every night. Reason for "insomnia" Ain't sleeping cause he's like a horny hamster on coke. 2000 grand prix gtp: SOLD My Home Theater Build (working progress) 2002 accord coupe subs: 2 soundqubed hds300 12s 4'1" towers tuned to 29hz sub: AQ hdc3 12 Amp: pioneer gm9061 amp: poineer gm9601 headunit: kenwood kdc 255u mids: SQ pro mids midbass: polk db 8s highs: stock mids/highs: shitty off brand
