Joe X Posted February 19, 2014 Report Posted February 19, 2014 It's down to 33Hz now and would hit pretty good lows in almost the same size. It would likely be better for your output to do something larger due to the lower power if you are not planning to upgrade the amp. I would upgrade power before compromising your backseats functionality, also think about where are you placing the amps and other stuff.
Tallyfiman Posted February 19, 2014 Author Report Posted February 19, 2014 true i didnt know if my amp would be enough i saw that they were rated at 1000 rms but the ones im gettin have internal lead, cooling, and flatwind options on them so i heard that increases the rms by 500 or 600 so i wasent to sure, what would be a good amp for that set up then? and what should i do to my electrical system right now its stock
Joe X Posted February 19, 2014 Report Posted February 19, 2014 Depends on your budget, some decent not so expensive brands are CT sounds or Crescendo, something 2.5 - 3k would fit your subs, but make sure you have the electrical to back the power. You can also re measure to see if you can do the box a little larger, of course factoring in and extra battery maybe and your amps.
Tallyfiman Posted February 19, 2014 Author Report Posted February 19, 2014 so your saying it wouldnt be smart to put my back seats down because that would give me all the room i would need i think
Joe X Posted February 19, 2014 Report Posted February 19, 2014 Many people place all that stuff between the rear seats and the box taking advantage of the space that the slant of the backseats leaves available, it's one way to go, usually when designing a system you need to factor in everything before setting dimensions for your box, in your case I think it would work as it is now but do check everything before you start building.
Tallyfiman Posted February 19, 2014 Author Report Posted February 19, 2014 alright thanks and do you know of any good box design software i can download i build boxes for my friends and the one that re audio has just isnt cuttin it
Joe X Posted February 19, 2014 Report Posted February 19, 2014 Something similar to the RE is Torres calculator which you can download from this site, it's at least better than the RE.
bbeljefe Posted February 19, 2014 Report Posted February 19, 2014 WinISD Beta is a good modeling program that can be downloaded here. Facebook: facebook.com/audioanarchyllc Instagram: audioanarchyllc Youtube: youtube.com/bbeljefe
Tallyfiman Posted February 19, 2014 Author Report Posted February 19, 2014 Alright thanks I've heard of people doin boxes around 16 cubes and they say it gets nasty low tuned to about 30 hz so I'm probably gunna try that
Joe X Posted February 20, 2014 Report Posted February 20, 2014 If you go all the way up to get those extra 4 cubes, subs up /port back will fail, would be better idea to make it a wall (if that makes sense for a couple of SSDs).
