I want to build a box that will be 1.5 Cu FT
I’m lost on how to figure out how big the port should be want it to tuned to 35hrts
Is they a good site that can tell me how to figure the port size, and that Could tell me if the measurements I have would make it to be 1.5 C.U Ft
Also What is the equivalent measurement to 1 C.U FT
Moving where the Money Trees are
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
Thanks looks like everything has to be 15" to get the 1.5 I need ofcouse one wall will be slated so its not a a complete square box
But I still haven't found out what size the slotted port needs to be
Any help on how big the port should be
thanks for those links
What is the equivalent measurement to 1 C.U FT ie how many cm
Ok, there are roughly 2.5 cm per inch. so 12 inches would be 30.5 cm .now for inside dimension they would be 30.5 x 30.5 x 30.5. Outside dimensions would be about 32.5 x 32.5 x 32.5. That allows for the thickness of the MDF, that is if you use 3/4 in. MDF. Also, for the port, do you want it to be a slot port, or do you want to use a round port?
slotted port
with only 1.5 cu ft you are better off using a 3" piece of pvc about 8" long.
Michael Hughes = 6X SPL World Champion - Loudest on the planet in db Drag, USACi, and IASCA.
  • Who's Online   0 Members, 0 Anonymous, 907 Guests (See full list)
