Rockbrook Posted February 21, 2014 Report Posted February 21, 2014 Yesterday picked these Diamond Audio S6.0x xrossovers up for next to nothing on craigslist I have a pair of silk dome tweeters from my last Alpine Component set laying around. Currently I'm running no tweeters. If I hook Up everything the way it's supposed to, (Crossovers to amp, tweeters to crossover, front mids to crossover, and rear fill speakers to the raf on the crossover) everything should work fine and sound pretty good if not better than before correct? Here's a pic of them. Dont think I did too bad for $20
Aj11 Posted February 21, 2014 Report Posted February 21, 2014 what Amp are you running? it could be worth it it could not. personally i Like crossovers gives you that much more control. if you are running a 2 channel Amp to front door speakers then yes i would use the croosover to add the tweets. its kind of a loaded question tho. what ohm are they? are you running mids in the doors or cox? jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
Rockbrook Posted February 22, 2014 Author Report Posted February 22, 2014 Im running the mids on a 2-channel mb quart raa2400, the mids im running now are actually eminence eminator. Supposedly their "car audio" line. They're 8 ohms. Have two wired in parallel on each channel of the mb quart. So right now its around 4 ohms per channel.
Aj11 Posted February 22, 2014 Report Posted February 22, 2014 so you have 4 mids and no tweets? then yes absolutely yes run the tweets. don't know what ohm they are but all should be fine jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
Rockbrook Posted February 22, 2014 Author Report Posted February 22, 2014 Yes lol 4 mids and no tweets. After I wire everything I'll check the final ohm load at the amp to be sure its not a crazy ohm load at the amp. Thanks for chiming in AJ
Stephen13 Posted February 22, 2014 Report Posted February 22, 2014 Do you know what impedance the crossovers were designed for? 4 ohms is typical for a mid-woofer but tweets can often times be 8 ohms as well as 4 ohms. A 1st order crossover designed for a 4 ohm load @ 4kHz would use a capacitor twice the value of one designed for an 8 ohm tweet. 2011 Chevy Silverado LT 5.3L 4x4 Ext.-cab "Enjoy yourself. It's later than you think."
Rockbrook Posted February 23, 2014 Author Report Posted February 23, 2014 Dont know for sure what ohm the crossovers were designed for. I'm 99% sure the mids that the crossovers came with were 4 ohm though, so maybe i should wire the speakers in parallel like i already have them to to the crossovers and forget the rear fill section on the crossovers.What ya think?
Aj11 Posted February 23, 2014 Report Posted February 23, 2014 what ohm are the tweets? id just run them and call it a day. figure out final ohm And set. either way tweets are gonna sound better then not having them jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
Rockbrook Posted February 26, 2014 Author Report Posted February 26, 2014 ok so today hooked everything up, i think the tweets ended up being 4 ohms, and my final resistance at the amp on each channel ended up being 4 ohms. When I first heard the music coming from my speakers I was amazed. Its amazing at how much of a difference those crossovers and the tweets made. My system actually sounds clean as fuck now. Preciate the help fellas
BoomZoom808 Posted February 26, 2014 Report Posted February 26, 2014 nice find I am using some re branded Diamond D6 X-overs in my Mazda and they take 100rms clean no problem. The RAF terminals do this ---> In addition to the woofer and tweeter outputs, each crossover has a third output for a Rear Acoustic Fill (RAF) speaker. The RAF speakers are powered by the same 2-channel amp as the component set and are apportioned 15%-20% of the total power. The RAF output is full range. Havent messed with the RAF yet its there. You should also be able to adjust tweeter attenuation and phase using the jumpers inside but if it sounds good no need 2010 Mazda 3s 2.5L Pioneer DEH-X9600BHS Knu OFC 1/0 SS Platinum AGM / XS Power XP750 Alpine PDX F-4 / Morel Maximo 5 + Coax 5 IA 10.1 / SSA XCON 12
