speakers and sub pop when the car shuts off.
Not trying to threadjack just trying to pose a question that might also help the threadstarter. Could you just run the amp grounds back to the battery and avoid and chance of groundloop feedback?
i had this same question but about having a battery in the trunk. if you have a battery in the trunk cant u run your amp grounds off the battery in trunk ?
2002 Mustang GT Procharged
Procharger P1SC Supercharger, 8psi
Procharger Intercooler, Headers,
Borla Off Road X-Pipe Exhaust, Mass Airflow
Upgraded Fuel Injectors
SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
give your replay a wire straight from the batt, hook your remote and a ground to the switch part on relay. and last part goes to amp. gives the amp your battery power and not just a 12v remote, then when your shut off your car, your remote volts drop making the noise possibly.
if the car doesn't stall, you have enough voltage.
DEH-6400BT
BC3500D on 2 x 12" Lanzar Opti1233d
QBOMB 4.5cu
1/0 awg, Lanzar AMPKIT0
Singer 275 + LCAKT50DBL
if thats the setup you wish to have. and it wont hurt to give it a test.
DEH-6400BT
QBOMB 4.5cu
try and aux cable with rca ends on your phone and see if there is any type of feedback.
DEH-6400BT
QBOMB 4.5cu
ok so today i tried takeing a wire and connecting to housing of the radio, from the negative of the rca connector. and sure enough my engine noise and turn on/off noise went away.
from the negitive of the rca, to what? the ground of the head unit?
DEH-6400BT
QBOMB 4.5cu
your desk has its own ground right?
DEH-6400BT
QBOMB 4.5cu
  • Who's Online   0 Members, 0 Anonymous, 4316 Guests (See full list)
