Building a box for two Digital Designs 9518i sc
AZaudio
Height 29" you should be too near the roof, subs up / port back is not going to work well, consider a wall.
Why would it not work well?
I could add more depth to work with if need be to accommodate
[*]DC Neo 15"
[*]Digital Designs M3a
[*]Audioque Super Tweets
[*]SoundQubed 6.5" Mids
[*]All Knukonceptz 1/0 w/ Big 3
[*]XS Power D6500
[*]Pioneer DEH-80PRS
Maybe you could go all the way to the back and do subs / port up (across the back) and lower the height of the box but neither this configuration has been very successful to many of those who tried in any case you would need to deaden the roof, that is a very decent deadening job, if it was me I would probably still do a wall.
My skills are not wall ready yet
Deadening wont be an issue for me, especially materials
Edit: I could get rid of the plastic cover on the hatch to add another couple of inches
[*]DC Neo 15"
[*]XS Power D6500
Yes walls are a lot of work no doubt, here is the alternative to subs up / port back I was talking about:
With the space gained you could lower the height of the box, still you would need, as said to deaden firmly the roof.
I would much rather do this design than a wall for now.
How could I come up with dimensions for the box above?
[*]DC Neo 15"
[*]XS Power D6500
I believe this will work but I don't know what to do about port dimensions
[*]DC Neo 15"
[*]XS Power D6500
How can you wire two 4 Ohms subs to 2 Ohms ?
Two DVC 4 OHms subs ::::>1 or 4 Ohms on the amplifier. That's what I think.
For the box : double layer is a good idea, but you can use a lot of bracing instead : you may gain weight, and have a stronger box.
I am sorry, you are right, I meant wire to 2ohm per sub.
So looks like I will be using rods and a double baffle, thanks
2ohm per sub to a mono amp still will equal 1ohm. It's a mono amp not a 2channel
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
I get what you're saying. I worded it incorrectly twice. I completely understand that I will be going from a 4ohm load to a 1ohm load
[*]DC Neo 15"
[*]XS Power D6500
Building begins today, any input appreciated
[*]DC Neo 15"
[*]XS Power D6500
[*]DC Neo 15"
[*]XS Power D6500
  • Who's Online   0 Members, 0 Anonymous, 3290 Guests (See full list)
