33hz Posted February 23, 2014 Report Posted February 23, 2014 i have 2 dvc 4ohm subs inverted so changing the resistance is waseasy for me. if you guys tell me what to do I'll run out change the wiring And make a video. i know your talking about dual 2ohm but you should still see the affect. i know my amp can take .5ohm so no worries on the low end. i can make a short videoOh ok you have dvc4 subs, I misread it. But yeah the same method applies and you'll see 1.6Ohms.It's easy enough to wire it up, you'll only need to change one sub. As for how to do it... That's a little hard explain in text so just look up a sub wiring diagram series vs parallel and do one of each Basshead not audiophile
Aj11 Posted February 23, 2014 Report Posted February 23, 2014 all i need to do is run one at 2 one at 8 correct? then put both to my mono Amp right? I'll go do it now. I'll use a 40hz test tone should help see movement better sorry 30hz jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
33hz Posted February 23, 2014 Report Posted February 23, 2014 Yup. You know how right? Basshead not audiophile
33hz Posted February 23, 2014 Report Posted February 23, 2014 Here you go. You like the fancy diagram program I used? LOL Basshead not audiophile
Aj11 Posted February 23, 2014 Report Posted February 23, 2014 just did it, even checked my coils with my ddm before to make sure. the vid is loading now. at the end of the vid i said ten hertz to 1 i meant 20hz to ten sorry. will post as soon as its done loading jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
Rail Posted February 23, 2014 Report Posted February 23, 2014 This is simple ohm's law calculations. It is bad to have different impedance subs because each will receive different amounts of power. If the subs are free aired or have separated chambers, they will definitely have different excursions. The one receiving higher power fail first, then the other will likely fail shortly after because all of the current will then be only flowing through the remaining sub. Ohm's law: V = I*R (Voltage = Current * Resistance) How to find resistance in parallel: (R1-1 + R2-1 + R3-1 + R4-1 + ... + RN-1)-1 Where R = resistance of each coil, and you may have as many R as you like Simple example coming from a Physics textbook: Chevrolet Tahoe Crescendo PWX6 (2) and FT1 (2) Fi Audio SP4 15" (1), AQ3500D.1 (1) Enclosure: 4th Order (Ported) 4.5cu ft @26Hz Mechman Elite 370A & Kinetik HC2000 Sky High 2/0 Wire Future Plans: (2) 18" @25Hz
Rich Schenk Posted February 23, 2014 Report Posted February 23, 2014 Like how u pulled out the physics book for that. On 3/28/2014 at 4:22 PM, KyLar96 said: Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science... Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/ 2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/ 2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
Aj11 Posted February 23, 2014 Report Posted February 23, 2014 don't know why that didn't work jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
Aj11 Posted February 23, 2014 Report Posted February 23, 2014 http://s846.photobucket.com/user/pasquariello1104/media/Mobile%20Uploads/VID_20140223_160933_635_zpsd5e5c540.mp4.html should mention box is shared air space jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out)
Rail Posted February 23, 2014 Report Posted February 23, 2014 I was doing Physics work but got a little distracted and saw some misinformed people... Let the truth be spoken! Plus I had to stay to see the video, which does back up the math behind it. His sub at 2 ohms should have been getting 4 times as much power as the one at 8 ohms, and that's what it looked like. Car audio is practically a science, do it right and you get loud. Chevrolet Tahoe Crescendo PWX6 (2) and FT1 (2) Fi Audio SP4 15" (1), AQ3500D.1 (1) Enclosure: 4th Order (Ported) 4.5cu ft @26Hz Mechman Elite 370A & Kinetik HC2000 Sky High 2/0 Wire Future Plans: (2) 18" @25Hz
