dd-1 setting gains on strapped amps .
No, when Matching gains, you set both. Then hook a DMM up to them to read the output voltage. Then you take the lower of the two numbers, and make sure both your amps are showing the exact same number.
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
You set both the slave and master amplifier with the DD-1. Then you take a Digital Multi Meter and measure each amplifiers DC(is that right?) voltage(if not AC). Write both numbers down, and then you retune the higher of the two amps to the lower voltage, so that both have the same exact voltage showing. Master/Slave functions is only there to tell the other amplifier to turn on.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
you are correct if i was to run each amp as a single setup but when u strap the master controls both amps .
If the technology of that specific amplifier is like that, where you set all settings on master amp than yes, leave the slave alone. I lokoed past that fact when I was explaining. I was thinking of using 2 non strappable amplifiers to gain match.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
i appreciate u trying to help and trying to be respect full here but u obviously have never used amps strapped because all of the ones i have seen work like what i described the master will control the slave ( this is not my amplifier specific ) dc, sundown,dd,ampere audio,crescendo etc
also i do not wish to experiment or assume i would rather have somebody that has actually used the dd-1 on a strapped setup post from experience .
thanks
  • Who's Online   2 Members, 0 Anonymous, 1937 Guests (See full list)
