LOWHERTZ75 Posted February 24, 2014 Report Share Posted February 24, 2014 i have been using the dd-1 on single amp setup for a while and recently decided to go with 2 strapped so my question is do i set the gain on master and assume once strapped they will both be set correct ? i looked around the dd-1 manual and it does not mention anything about this topic. Quote Link to comment Share on other sites More sharing options...
Ahmed Johnson Posted February 24, 2014 Report Share Posted February 24, 2014 Damn that is a good question. Quote Link to comment Share on other sites More sharing options...
RooTxBeeR Posted February 24, 2014 Report Share Posted February 24, 2014 No, when Matching gains, you set both. Then hook a DMM up to them to read the output voltage. Then you take the lower of the two numbers, and make sure both your amps are showing the exact same number. Quote On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5 Link to comment Share on other sites More sharing options...
Ahmed Johnson Posted February 24, 2014 Report Share Posted February 24, 2014 Yeah but what about strapped? The slave amp gain is all the way down. Quote Link to comment Share on other sites More sharing options...
RooTxBeeR Posted February 24, 2014 Report Share Posted February 24, 2014 You set both the slave and master amplifier with the DD-1. Then you take a Digital Multi Meter and measure each amplifiers DC(is that right?) voltage(if not AC). Write both numbers down, and then you retune the higher of the two amps to the lower voltage, so that both have the same exact voltage showing. Master/Slave functions is only there to tell the other amplifier to turn on. Quote On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5 Link to comment Share on other sites More sharing options...
LOWHERTZ75 Posted February 24, 2014 Author Report Share Posted February 24, 2014 No, when Matching gains, you set both. Then hook a DMM up to them to read the output voltage. Then you take the lower of the two numbers, and make sure both your amps are showing the exact same number. you are correct if i was to run each amp as a single setup but when u strap the master controls both amps . Quote Link to comment Share on other sites More sharing options...
LOWHERTZ75 Posted February 24, 2014 Author Report Share Posted February 24, 2014 (edited) oops dbl post . Edited February 24, 2014 by LOWHERTZ75 Quote Link to comment Share on other sites More sharing options...
LOWHERTZ75 Posted February 24, 2014 Author Report Share Posted February 24, 2014 Yeah but what about strapped? The slave amp gain is all the way down. u are correct once strapped the slave setting do not matter Quote Link to comment Share on other sites More sharing options...
RooTxBeeR Posted February 24, 2014 Report Share Posted February 24, 2014 No, when Matching gains, you set both. Then hook a DMM up to them to read the output voltage. Then you take the lower of the two numbers, and make sure both your amps are showing the exact same number. you are correct if i was to run each amp as a single setup but when u strap the master controls both amps . If the technology of that specific amplifier is like that, where you set all settings on master amp than yes, leave the slave alone. I lokoed past that fact when I was explaining. I was thinking of using 2 non strappable amplifiers to gain match. Quote On 11/20/2012 at 8:54 PM, AMI CUSTOMS said: Turned mine up today at a light, guy next to me his steering wheel started moving and he looked over at me like I was a magician lol. On 5/9/2012 at 8:45 PM, skittlesRgood said: fuck the plating. look at what the main metal used is. you could buy unicorn blood plated terminals but if its just covering up dog shit, whats the point On 4/10/2013 at 12:26 PM, mrd6 said: I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha Soon To Be '04 Ford Escape US Alternator 280A Hairpin D4800 Under the Hood (6) XP3000's in Rear 1/0 SHCA & XS Power 4 runs to back TORK2 kit from Tony @ CE Auto Supply Pioneer DEH-80PRS DD AW6.5 (2) per door *Tweeter Unkown* DD SS4a & C3d (2) SCV4000 @ .5Ohm (2) 15" Sundown Zv5 Link to comment Share on other sites More sharing options...
LOWHERTZ75 Posted February 24, 2014 Author Report Share Posted February 24, 2014 No, when Matching gains, you set both. Then hook a DMM up to them to read the output voltage. Then you take the lower of the two numbers, and make sure both your amps are showing the exact same number. you are correct if i was to run each amp as a single setup but when u strap the master controls both amps . If the technology of that specific amplifier is like that, where you set all settings on master amp than yes, leave the slave alone. I lokoed past that fact when I was explaining. I was thinking of using 2 non strappable amplifiers to gain match. i appreciate u trying to help and trying to be respect full here but u obviously have never used amps strapped because all of the ones i have seen work like what i described the master will control the slave ( this is not my amplifier specific ) dc, sundown,dd,ampere audio,crescendo etc also i do not wish to experiment or assume i would rather have somebody that has actually used the dd-1 on a strapped setup post from experience . thanks Quote Link to comment Share on other sites More sharing options...
