ground zero audio GZRW 38SPL 15" enclosure
yogles
Just replacing my 2 12" Precision Power subs with a Ground Zero 15" sub and was wonderin what enclosure desing and size to use? Have about 1500W@1Ohm mono amp. Sub specs are as follows
Model GZRW 38SPL
Diameter 380 mm / 15"
Mounting diameter 356 mm / 14.1"
Mounting depth 191 mm / 7.52"
Voice coil 75 mm Runddraht / 3" Round wire
Power Handling 1500 W
Impedance 2 x 2 Ohm
SPL 93 dB
Xmax 22 mm / 0.9"
Fs 33 Hz
Qts 0.38
Vas 93 L / 3.28 cu.ft.
Any help would be appreciated
Need to tell vehicle, amp models and max dims for the box.
Joe your a mad man. You pop up everywhere, drop off box designs and disappear just as quick.
  • Who's Online   0 Members, 0 Anonymous, 3164 Guests (See full list)
