Looking for a new amp...
jrussell9109
What's up everyone, so I'm looking for a new amp to give me more power. My current setup is a Alpine Type R 10D2 wired to 2 ohms on a Arc Audio 600.1 running 620rms at 2 ohms. I'm looking for something around 750-850w rms because I'm not to sure about running my sub at the actual 1000w rms that the sub can handle. Any suggestions?
almost everything > hifonics.
dc would be a good choice.
if you run the woofer at 1 ohm on a dc 1.2k, the woofer wont even see 1000w anyway because of voltage drop and a shit ton of other factors.
What's your budget, and try and stay away from hifonics if possible.
truthsayer
Soundquebed, Q-1200. Or CT Sounds 1400.
truthsayer
You have a dual 2 sub correct? If that's true you can not wire to 2ohms. It's eather 1 or 4ohms I would venture to say you have been running at 1 ohm this whole time. Also the little bit of power you are looking at will not be much of a gain. To really here a difference in how loud it is you need to double power. With that being said sq 1200 and wire that bish to 1 ohm and let it wang
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
That Type R can handle more than rated...
I'd stay away from the Hifonics Zeus line. The rest are okay amps but there are a lot better for the money. For your application I'd recommend the CT Sounds 900.1 for 1Ω or the 1400.1 for 2Ω.
Facebook: facebook.com/audioanarchyllc
Instagram: audioanarchyllc
Youtube: youtube.com/bbeljefe
I believe the Rockford prime 1200 does 800 at 2 ohm
06 monte carlo
2 12 rockford p3s
soundstream rubicon 2500
crescendo audio mezzo 6.5
ct sounds 125.4
execution audio and shca wiring
2 xs d3400 on stock alt
  • Who's Online   0 Members, 0 Anonymous, 582 Guests (See full list)
