problem with two rockford fosgate p1's 12" 500w 250 rms
onureemus
if i listen to bassy songs the woofers get hot-ish or warm in the middle of the sub where there is the lil center point what p1's have, but theres no strange smell tho , am i good to go or need i crack the volume down ? im running them in doors with a Yamaha power amp
allways be aware of cats
What kind of box? Sealed or ported. The heat you feel is from the voice coil heating up, usually not a good sign unless that's your thang.
its ported but the box is a lil small and i just got em so i should turn down the volume prob ? its not like smelling or anything but its not good right ?
They meaning the box?
two seperate boxes and ported useing only one sub now tho forgot to add english is my scd langue so srry if i dont amke sence and cant understand some things
Slightly smaller than recommended box should not cause your coils to heat up. Most likely a distorted signal from your amp. If your amp has a subsonic filter set it for 26-28hz turn the volume down on the receiver and bump it up a little on the amp. You could be clipping, causing the the coil to heat up.
That's what I was thinking. How did you set your gains?
I think he is using a PA type amp, or a home stereo receiver. Now that I think about it if it is a stereo receiver it has no HPF sending the full range to the sub. In home tower speakers there are usually passive crossovers or resistors in series with each speaker.
ok il work on it , and on 26-28 hz the amp dont pump out enough to make any sound but imma make new boxes anyway bcs the port on the current one is scaure and i think its small and the box is small too and i have a Yamaha P5000s power AMP for studio use it has a filter built in for subs
  • Who's Online   0 Members, 0 Anonymous, 2683 Guests (See full list)
