How Much Port Area for Team Fi 15
cubs_fan0718
As the title states what would be the optimal port area for 1 Team Fi 15? I was thinking between 14-16 but im not really sure. If it matters mostly for daily but I will be competing with it also.
06 Impala SS
Kenwood Excelon DDX593
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
Mechman 320a Alt. w/ Big 3
Under Construction for 2017
You shouldnt go with the # of in^2 per cube, that is more of a rule of thumb and with that nice of a sub I'd wait to figure out an ideal box design. Not just a rule of thumb.
Hopefully someone can come in and comment on how many in^2 of port is recommended for that particular sub. I'd guess about the same as an sp4 so around 60in^2 but maybe blfok4* can chime in since he seems to have a lot of knowledge about fi/aa subs and box design.
I've gotten a blowjob and picked up my iphone behind her back to see what email notification I got from smd before
Port area should be based off of the driver(s) in use, tuned frequency, and the xmax of said drivers. At certain area's you can only the air moving up to a certain velocity before it starts to negatively affect your output, driver, and response. Once you go over said maximum velocity you encounter those problems. This is called port compression.
After you start getting close enough to the amount of area you need flares become a good factor to work with as well, port flares allow a controlled change in velocity as air exits a port. This can prevent turbulence in the boundary layer, close to the port wall, from becoming audible. As the airspeed is lifted a little further, turbulence within the straight section of the port becomes an issue.
Let's use this graph as an example, it shows how with a higher diameter you get a higher usable port velocity and then shows how different flare radii affect it as well.
The red numbers just mean that you can't get any higher velocity from that diameter no matter how much larger you make the flare radius.
As for how much port area for a single 15" Team Fi, you can't get a recommendation until you decide a frequency to be tuned at.
Krakin's Home Dipole Project
Im shooting for a 32hz frequency.
06 Impala SS
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
A good quick calculator that gets pretty much as close as needed is here:
http://www.carstereo.com/help/Articles.cfm?id=31
But if you prefer doing the math yourself you can get them here:
http://www.carstereo.com/help/Articles.cfm?id=21
http://www.diysubwoofers.org/misc/portcal.htm
Doing port calculation with this "simple" equations can only get you within +10% of the minimum port area with a well rounded flare. The only way that is sensible to figure out the absolute best is to do testing with multiple enclosures.
And of course you can get much much more complicated, but it is not really necessary for the average person building/designing enclosures.
thanks, I will check into those sites you have suggested.
06 Impala SS
Ampere Audio 150.4
Ampere Audio 5K
1 XS D4700 (front)
  • Who's Online   1 Member, 0 Anonymous, 1362 Guests (See full list)
