bass_lord Posted July 16, 2014 Author Report Posted July 16, 2014 36 inches wide.... 18 inches tall.... 46 inches deep.... the port and subs are facing up.... the port is 4 inches wide and 34 inches long and goes 12.5 inches deep into the box...
SlamminBeats Posted July 16, 2014 Report Posted July 16, 2014 in all reality op if you want hair tricks tune low... A loud system from 30-50 hz will move air and hair. so just build it right and youll be fine.
CleanSierra Posted July 16, 2014 Report Posted July 16, 2014 So the port opening is 4X34"? Is that the mouth of the port's dimensions? Im not the one you want to try to troll. Just a fyi for you.
SlamminBeats Posted July 16, 2014 Report Posted July 16, 2014 So the port opening is 4X34"? Is that the mouth of the port's dimensions? will be noisy
CleanSierra Posted July 16, 2014 Report Posted July 16, 2014 Yikes! That's like an 8:1(8.5:1 top be exact) ratio. Do you have the port flared with a router on the outside or is it simply flat and square wood? Im not the one you want to try to troll. Just a fyi for you.
bass_lord Posted July 16, 2014 Author Report Posted July 16, 2014 The box sounds pretty good... but for some reason i feel like its not tuned correctly.... i still have my 13w7 and its box is tuned to 32Hz... and it sounds like it gets lower... i mean do get me wrong... im getting mega roof flex but im not sure if he built the box right...
bass_lord Posted July 16, 2014 Author Report Posted July 16, 2014 Its simply flat with square corners... plus theres no bracing inside of the box...
Cj Kumz Posted July 16, 2014 Report Posted July 16, 2014 Your port area is too little and that's . Just do a new box. Or you can seal up that port and put in aero ports. Its just a suggestion but could actually work out better you Vw Polo Pioneer Deh-6050UB Sundown Saz-3500d DD Audio 9500 15'' 5.5 cubic feet box with 10 inch port @ 38hz I live to hear the Bass drop!!!
