Box Help (Hair Trick)
bass_lord
I finally found a second Fi 18 Btl (UFO magnet). Now i need ideas on a box that is capable of doing hairtricks. I drive a 2001 GMC Jimmy 2 door.. How many cubic ft. do i need and how much port space is need to do a pretty nice one. Im open to all suggestions. Space really isnt an issue. I can use as much as needed as long as the box stay 36-38 inches wide... i dont care how deep it goes..
Wall dat bitch add lots of power and tune it to like 28hz and only play decaf. = hair tricks
Chick took 3 shots of Jager, and then, pissed in my mouth.. oh.. wait.. naw.. that wasnt weird..
He probably tearin dat ass up every night. Reason for "insomnia" Ain't sleeping cause he's like a horny hamster on coke.
2000 grand prix gtp: SOLD My Home Theater Build (working progress) 2002 accord coupe
subs: 2 soundqubed hds300 12s 4'1" towers tuned to 29hz sub: AQ hdc3 12
Amp: pioneer gm9061 amp: poineer gm9601
headunit: kenwood kdc 255u mids: SQ pro mids
midbass: polk db 8s highs: stock
mids/highs: shitty off brand
You'll need more than just an enclosure to do a hair trick.
Definitely need an amplififer. What do you have?
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
Wall dat bitch add lots of power and tune it to hair trick and only play decaf. = hair tricks
Fixed
Ahh fuck I forgot 28 is for daily. Gotta tune it to hair trick bro.
bass_lord, do you still have that JL amp and that other not-so-great amp?
Are you looking for advice on building an enclosure SPECIFICALLY to hair trick? Cone area and power are the two big ingredients in getting a hair trick. Simply building a wall, tuned to 25 Hz on a couple thousand Watts isn't the formula for guaranteeing a hairtrick. How many boxes have you built, you don't have any post history so I can't track anything down that would give me an idea.
nvm listen to clean sierrra.
Now are you keeping the back seat and staying in the cargo area, or you removing it so you can have a huge box? You will get louder if you remove it, and build a long box with about 170+ port area tune around mid 30's blazers tend to peak in the low 40's.
Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell
Kenwood H/U
1/0 wire,
136 amp alt 200 ah batteries 12.7 daily
2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts
Mb quart 125.4 wired to 4 aura 6's
3.6 cube box tuned to 36 plays down to 23hz
  • 4 months later...
Well... i have 2 SAZ 1500 strapped... and a had a box made... but im not sure if it turned correctly... i wanted 30 Hz.... i can give the dimensions if any of guys can help me out...
  • Who's Online   0 Members, 0 Anonymous, 4010 Guests (See full list)
