GXPJONES Posted March 1, 2014 Report Posted March 1, 2014 Hi I Am Driving A 2008 Pontiac Grand Prix GXP And I Plan Doing A Build. I Already Have Sufficient Electrical Upgrades Installed So Im Just Looking For What # Of Subs Will Work Best With Space Given. Budget Is About $1200 But I Can Increase A Bit If Need Be Thanks All Input Will Be Appreciated Usable Dimensions:33Wx15Hx42D Amplifier: Crescendo 2200
youngbass98 Posted March 1, 2014 Report Posted March 1, 2014 2 12s 06 monte carlo 2 12 rockford p3s soundstream rubicon 2500 crescendo audio mezzo 6.5 ct sounds 125.4 execution audio and shca wiring 2 xs d3400 on stock alt
GXPJONES Posted March 1, 2014 Author Report Posted March 1, 2014 Anyone I Could Possibly Get A Box Design From? Ill Most Likely Run The SQ HDS3 12's
agf144 Posted March 1, 2014 Report Posted March 1, 2014 well what are your max dimensions Chick took 3 shots of Jager, and then, pissed in my mouth.. oh.. wait.. naw.. that wasnt weird.. He probably tearin dat ass up every night. Reason for "insomnia" Ain't sleeping cause he's like a horny hamster on coke. 2000 grand prix gtp: SOLD My Home Theater Build (working progress) 2002 accord coupe subs: 2 soundqubed hds300 12s 4'1" towers tuned to 29hz sub: AQ hdc3 12 Amp: pioneer gm9061 amp: poineer gm9601 headunit: kenwood kdc 255u mids: SQ pro mids midbass: polk db 8s highs: stock mids/highs: shitty off brand
Meka Posted March 1, 2014 Report Posted March 1, 2014 Make sure you measure the trunk opening too. One thing I've found out, unless you plan on building in the trunk, the smaller setups can be louder than cramming in larger sub/s. For example 2 10's in great enclosures, have a pretty good chance of being louder than 2 15's crammed in theere with too little of space.
GXPJONES Posted March 1, 2014 Author Report Posted March 1, 2014 I already measured the opening is 42W so I have plenty its just my trunk does this weird curve towards the seats which makes 33 the usable measurement
agf144 Posted March 2, 2014 Report Posted March 2, 2014 I already measured the opening is 42W so I have plenty its just my trunk does this weird curve towards the seats which makes 33 the usable measurement It's the wheel wells. Mine is the same way only urs is a lot newer than mine Chick took 3 shots of Jager, and then, pissed in my mouth.. oh.. wait.. naw.. that wasnt weird.. He probably tearin dat ass up every night. Reason for "insomnia" Ain't sleeping cause he's like a horny hamster on coke. 2000 grand prix gtp: SOLD My Home Theater Build (working progress) 2002 accord coupe subs: 2 soundqubed hds300 12s 4'1" towers tuned to 29hz sub: AQ hdc3 12 Amp: pioneer gm9061 amp: poineer gm9601 headunit: kenwood kdc 255u mids: SQ pro mids midbass: polk db 8s highs: stock mids/highs: shitty off brand
jarrius Posted March 3, 2014 Report Posted March 3, 2014 Also take in to count when your lid closes. Don't know about your car but mine has 2 hinges that make my usable hight go from 20 to like 14.5 or so 2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d 140 square foot of Q-Mat(soon to be installed) 140.2Db sealed on the dash with TL 142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at) 141 on music. strangeduck,on 02 Jan 2014 - 01:39 AM, said: when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
Swordlordboy1234 Posted March 3, 2014 Report Posted March 3, 2014 soundstream15 has the same car as you. check out his build log. My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37 My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/ 2016 Mazda 6 Touring JL Fix 86 - OEM signal correction B2 prototype DSP 6to8 B2 Ref63 - 3 way active set 2 B2 Class H quattro's 1 B2 Zero.5R @.5 2 B2 HNv3 12 d2 B2 SLIP40 - Lithium in the trunk Northstar Group 35 under the hood 100ft 2/0 welding cable 30ft 4ga welding cable 20ft 8ga welding cable All stinger OFC speaker wire Soundrive custom RCA's Tons of attention to detail.... Can it be perfect?
