Port explanation please.
I'm sure this is a stupi question to most of you but hopefully someone. Will explain it to the slow guy here. I just got an email from re audio regarding the two xxx 12s I'm installing in my dakota. They recommend 7.5cuft for a common box which I understand but they say 56 sq/in of port 12 in long. For some reason that's where I'm getting g lost. Am I making a port apx 4 1/2 inches deep and 12 inches long?
It means the opening of the port will have an area (height x width) of 56 sqin, and the port will be 12" long.
Example: a port 16" H x 4" W and 12" deep.
That is a big box for a pair of 12's, and their suggestion gives a 35 Hz tuning.
Not what I would do. . .
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
2.2 cubes net per sub to 34 Hz is their published suggestion, I'd give more port area depending on tuning.
I think what bkolfo4 meant was an example for you would be 14''h x 4''w and 12'' depth. That would give you your 56 sqin of port.
truthsayer
the 7.5 cubes could be gross wich with sub and port displacement should drop it what 2 cubes or so? if thats correct that is aobut 5 cubes for the 2 12's.
From what i just read on RE's websight 2.2 cubes per sub (after displacement i would assume) so you would want about a 5cube box if i am correct. BTW each sub displacement is .25 so 2 is .50 cubes ^_^
2012 Chevy sonic1xSQ HDC3 12 D2RF R1200d
140 square foot of Q-Mat(soon to be installed)
140.2Db sealed on the dash with TL
142 DB sealed on the dash with another meter (was dead on with the TL at a show i was at)
141 on music.
strangeduck,on 02 Jan 2014 - 01:39 AM, said:
when my car spins out i just put the car in neutral, turn in the direction i want to go and pucker my asshole
If they meant 7.5 cuft gross, then the 56 sqin port that is 12" deep will take up ~.4 cuft. Subs take up .5 cuft.
Let's estimate it leaves 6.5 cuft net.
Still too big and makes the tuning even higher.
Better start from scratch and forget their suggestion.
5 cuft net with 70-80 sqin of port tuned to 34 Hz would work great for a pair of those.
Current system:
Previous systems:
  • Who's Online   0 Members, 0 Anonymous, 3164 Guests (See full list)
