Amart88 Posted March 8, 2014 Report Share Posted March 8, 2014 You guys have any tips on glassing door panels? I mocked up all of my rings with hot glue, stretched over the fleece. Hard to get perfect. My staples are barely wanting to go through the plastic and I already blew a few holes in the plastic from the staples... Then to top it all off, some of the hot glue joints failed when I was stapleing around the flush mounts... FML Also, I used 3m spray adheisive to hold shit down. I got the fleece all soaked in resing right now.. I'm having a hard time keeping it tight around the edges of the door. Keeps wanting to lift out of the crease. I managed to shoot a dozen staples in it but damn. I need to figure this out before I do my other door... My 2005 s10 blazer build. 4 zcon 18's walled. Link to comment Share on other sites More sharing options...
deadbroke Posted April 23, 2014 Report Share Posted April 23, 2014 Not sure if it helps now but you can buy a pnuematic stapler and staple the fleece or whatever cloth to the backside after its stretched around the front and around the sides. When setting the rings you can use a glue gun and use dowel rods for posts if you drill a hole for the leg it helps anchor it to the panel. Panels are hard to mount to because of the difference in materials but if its near a speaker you can cut out all of the materials from the backside after the initial form has hardened so you can just screw a base to the panel and work off that. I just finished some door panels and wish someone would have gave me some of this advice Link to comment Share on other sites More sharing options...
