Joe X Posted March 20, 2014 Report Posted March 20, 2014 Kicker Comp C10 work in 1 cubic feet each "sealed compact" suggestion, so 4 cubes net which you don't have either in those 13.75x36x14 even if the box didn't have the loss of airspace due to the slanted baffle. Cone area is worth nothing if you don't have the space to back it up, with 14x36x18 I would do a couple of DC Audio 12s level 2 or 3 (which work well in small boxes) and you would get way, way better results.
dsw422 Posted March 20, 2014 Author Report Posted March 20, 2014 Ok, so what if i go with 2 Fi BL 15's in the box i drew above instead of the 10's??? that box will be almost 5 cubes with the port.. itll be cheaper to get 2 subs rather than 4... what amp would you recomend for the bls too?? 2014 Ford Focus SE Sedan Factory Sony 10 Speaker Sound System 1994 Ford Bronco Dual head unit (i kno) Sony door speakers Kenwood Rear Speakers Custom Center console in the works. will house an NVX NSW10" https://m.facebook.com/WinnsCustomCarAudio/
Joe X Posted March 20, 2014 Report Posted March 20, 2014 You don't have space for 15s (almost no one does in trunk cars) a couple of 12s of your choice which will fit in tight airspace like the DC audios or 5th generation Alpines, unless you can take all the possible trunk space and do a pretty larger box.
