Box tuning help!!!
dsw422
Ok.. So I already have my box made. I made it to fit 4 10" kicker subs, and fit inside my trunk. I love the look of it, but I need to figure out what it is tuned to cuzz I am going to change out the subs and amps.
Here are some pics of the build.
Thanks for your help everyone!!!
2014 Ford Focus SE Sedan
Factory Sony 10 Speaker Sound System
1994 Ford Bronco
Dual head unit (i kno)
Sony door speakers
Kenwood Rear Speakers
Custom Center console in the works. will house an NVX NSW10"
https://m.facebook.com/WinnsCustomCarAudio/
Sorry bro for the harsh words but i suggest you go back to the drawing board after doing a lot of reading up on this site.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Your net volume looks way low and your port layout is incorrect (cross-sectional area needs to be constant), that can't be sounding any nice regardless of the amp you use. I would also suggest a full redesign if you have enough space for 4 of them ported
SO that means that the port width should be the same all the way through correct?? If that is so, then should I add in some mdf to make the wider port areas smaller and change the beginning port (inside the box) 1.5 inches as well??
1994 Ford Bronco
Sony door speakers
If a full redesign is absolutely necessary. any ideas??? My Height cannot go any higher than 14" and my width 36" depth no more than 16". And all 4 need to face forward... hard to come up with a design.. huh??.. lol.. thanks for any help.. pics of ideas are helpful...
1994 Ford Bronco
Sony door speakers
Ok, so I thought about it... and I came up with a new box design...The subs will be top mounted now... I added another 2 inches to the depth, but w/e.. lol.. what do yall think?? it'll be one whole box instead of 2 ports like before.. 0319142139.jpg
1994 Ford Bronco
Sony door speakers
I would suggest against having your subs face up. Its just a recipe for trunk rattle that is not easily fixed. I actually think your original layout may be able to work, it will just need some of the dimensions tweaked a bit. The dimensions you listed in your first picture, are those inside dimensions or outside dimensions?
Builds:
Eliminate the port altogether and just clamshell them like you have. 4 subs sealed should sound really good.
I like your woodworking skills :)
Get rid of that port and just run sealed, rather than skimp on port area with all 4 subs. A nice sealed box can sound MUCH nicer than a ported box where internal volume or port area is sacrificed.
Agree
You have quite a bit of cone area, sealed will probably sound really good.
Builds:
Ok.. Ill go ahead and seal it up and remove the port.. If i dont like the sound of it sealed, what should i do? I still think my new design above would sound great.. if i do that i would definately seal off the trunk cuzz i too hate a trunk rattling... And what about the port? is it in a good spot or should i place it elsewhere like forward facing or so on??What do ya think???
1994 Ford Bronco
Sony door speakers
  • Who's Online   0 Members, 0 Anonymous, 3326 Guests (See full list)
