FuriousG Posted March 22, 2014 Report Posted March 22, 2014 I'm assuming you haven't checked for DTC's seeing as there has been no diagnosis besides lottery attempts. That would be a great place to start. You could have a lot of things happening, especially that engine. Cam actuator may be stuck or sticking(change your oil often?), phaser solenoid could be sticking or screens could be covered in crap (if the screens are even there anymore). Crank end play could be excessive, you'd lose ignition timing, and mechanical timing may be out depending on chain. I've seen a lot of melted battery feeds at C201, drops ignition signal intermittently. Broken wiring inside insulation to TAC motor. Low fuel condition, exacerbated by broken/missing baffles in fuel tank, does it start normally after stall? Start normally cold? Could be excessive carbon on valves..... Basically it could be a multitude of different things, find a shop that will scan for history DTC's for you. Otherwise it's more shotgun work.
dblovah51 Posted March 22, 2014 Author Report Posted March 22, 2014 furious g the ride has bin to the local gm dealership and all they could come up with is a new fuel pump which I do have in. I had someone scan it with a tech 2 and I got a evap code a lost of communication with BCM and PCM. I was told if the BCM was the problem the ride wouldn't start and security light would be on 2004 trailblazer 4 FI BTL 18s (2) DC 10.0k xs power d3100s mechman 270 158.2 @41
dblovah51 Posted March 22, 2014 Author Report Posted March 22, 2014 But after it stalls it starts right away n shut back off, if I floor it in time it sometimes stays on until I ease off the throttle then stalls out. 2004 trailblazer 4 FI BTL 18s (2) DC 10.0k xs power d3100s mechman 270 158.2 @41
justin0943 Posted March 22, 2014 Report Posted March 22, 2014 But after it stalls it starts right away n shut back off, if I floor it in time it sometimes stays on until I ease off the throttle then stalls out. that the eletric throttle body the senser in it is closing an choking the engine that the same that happen to my grandparents trailblazer it had no power and will all most stall we change a couple sencer no go so we pull the trigger on new body runs like a champ 02 dodge ram 1500 reg cab 3rd gen 2 sundown sd-2 d4 soundstream rub1.2500 amp all sky high car audio-fuse,fuse holder,wire,ring lugs and rca flex tech box design by Joe X supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch 04 5.7l hemi motor swap and made it an slt eletric everthing youtube channel-http://www.youtube.c...43?feature=mhee http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
dblovah51 Posted March 23, 2014 Author Report Posted March 23, 2014 I pulled the throttle body off my other trailblazer n tried it on the one with the problem but no fix 2004 trailblazer 4 FI BTL 18s (2) DC 10.0k xs power d3100s mechman 270 158.2 @41
justin0943 Posted March 23, 2014 Report Posted March 23, 2014 I pulled the throttle body off my other trailblazer n tried it on the one with the problem but no fix no you have to get a new one and take it to a chevy dealer to get it program trust me we tried to get a junk yard an thats what they told us 02 dodge ram 1500 reg cab 3rd gen 2 sundown sd-2 d4 soundstream rub1.2500 amp all sky high car audio-fuse,fuse holder,wire,ring lugs and rca flex tech box design by Joe X supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch 04 5.7l hemi motor swap and made it an slt eletric everthing youtube channel-http://www.youtube.c...43?feature=mhee http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
dblovah51 Posted March 23, 2014 Author Report Posted March 23, 2014 Oh ok thanks didn't think the throttle had to be programmed as well. Almost like every other thing on the ride 2004 trailblazer 4 FI BTL 18s (2) DC 10.0k xs power d3100s mechman 270 158.2 @41
matt14 Posted March 23, 2014 Report Posted March 23, 2014 Could be the torque converter clutch staying locked and causing the car to stall out 2006 GMC YukonPioneer HU SHCA ran throughout Crescendo BC3500 One 18 AA Mayhem in a 4th order ZED Levithian 6 channel Rainbow Dual 6.5 comps ran Activehttp://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
dblovah51 Posted March 23, 2014 Author Report Posted March 23, 2014 One technician did tell me smething about the converter but never came to check it for me its like I have to beg them to work on it for me. How do I find out if its the converter sticking 2004 trailblazer 4 FI BTL 18s (2) DC 10.0k xs power d3100s mechman 270 158.2 @41
dblovah51 Posted March 23, 2014 Author Report Posted March 23, 2014 It first occured one day I was speeding to work and as I got in the parking lot and put the ride in reverse it stalled and ever since its bin gettn worst til now its at the point that it can leave my yard. 2004 trailblazer 4 FI BTL 18s (2) DC 10.0k xs power d3100s mechman 270 158.2 @41
