Help Wiring 4 pin Singer Alt.
Got a 350 amp singer alt 4 pin... Trying to hook it up in an 07 silverado 5.3l that originally had a dr44g 2 pin alt( L and F pins)
Having some trouble getting this thing to work and have read a lot of different things about converting from 2 pin wiring harness into a 4 pin alt. Anyone have some advice?
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
Singer built the alt knowing the truck only had a 2 pin hookup. He said it could be done and would be more efficient by wiring up a 4 pin alt. He said he had done it before but he isn't responding to anything right now, I am guessing because of SBN. There is a way to hook up the 2 wires to this 4 pin alt and make it work, just can't seem to figure it out. I've made and inline resistor L wire like some places suggested but it did not work, the resistance between the L wire and ground is 598 ohms as is and that is supposedly too high. This thing has just become overly complicated, singers only instruction was to connect a switched power wire to the L pin but that didn't work. I figured someone else must have gone through this or knew of a diagram or something. PLease someone help
you only need 1 wire to make the alt work.. i wired mine directly to the ignition with a 500ohm diode inline and it is working
What wire and where on the plug does it go? The brown Wire as is has close to 600 ohms resistance I shouldn't need more right? Ive tried it with a 100 ohm inline resistor and still nothing...
I've done what singer said by wiring an ignition wire to the L pin and it did nothing
  • Who's Online   0 Members, 0 Anonymous, 487 Guests (See full list)
