Thats a nice one, does it run good?
U gave me an idea too, Shading the windows.
Check Out My 1986 Chevy Caprice Brougham Classic Restoration:
http://www.stevemeadedesigns.com/board/topic/184647-1986-chevy-caprice-restoration/
thanks....yheap..i change the motor i put it a 5.7 chevy vortec motor..but with the old carb..like i say im just starting to put some money on it..its gonna be like a gift for my dad and in the same time for me because im the one that use it now.
Its always nice seeing some American cars overseas, I had an uncle from Jordan, so I recognized aome letters.
Thats a very nice lloking Box Chevy, and seems you are on the right path as far as audio goes!!! Tuned in!
2003 Chevy blazer 4x2, it has a tape deck.
1999 Acura integra, whats a radio?
1983 kawasaki kl250R bobber, my phone is almost loud enough.
A bit of rust cased by the battery acid and radiator leakage
The trunk needs welding
This is the edges of the trunk from the inside "not rust"
I think theres a missing part over here and It needs to get brushed and cleaned
There is a little oil leak at I think its called "gasket"
had to remove the horns because they got stuck.. removed the computer too.
removed the little original speakers.
I discovered some problems In the car and I would like to get some help:
The left turn signal on the dash board is stuck (green arrow) and not blinking but when I turn it on It goes normally on the dash, another thing thats the temperature gauge is stuck at 100 as you can see in the pictures, and the windshield wipers keep going on and I cant stop them. thats all for now ,
Also I had a trouble with removing the back seat (back) theres a screw down there but when I try to take it off it keeps spinning ... so I couldnt remove it.
umm about the front seats, I couldnt remove the driver seat because I couldnt see the screws at the back I did the front 2.
the blinker light on means a light is out on that side somewhere check all the lights up front .
the 80s s10 and our 93 s10 do that when a bulb is out most of the time its a blinker/running light bulb
b8426b6f-6b19-45b2-aa60-f898a05a3587_zps
88 ranger xlt ext cab
HU. jvc bluetooth/usb deck
mids/highs. 2 earthquake 5s. 2 earthquake 6s and 2 Cadence CVLT-60 tweets
subs. 2 Addictive audio V4 12s
SAZ3000D
SAX100.2
alt. 135 amp ford mustang
batt. deka G31 1131MF
box. 4 cubes 30-34hz
rims. black 13x7 100 spokes with chrome knock offs.
tires. 155/80r13.milestar touring se
real billet grille not a bolt on.
HYDROS FINISHED!!!!! 2 pumps 4 batts
I get fucked by this old guy at work all the time. MY ASS WILL FOREVER REPRODUCE THE LOWEST AUDIBLE SUB BASS FREQUENCIES KNOWN TO MAN!
just because we think it ugly and it sounds like a bucket of smashed assholes.
Hanes. And dried jizz. It's better than fatmat
Jordan, cool to have a member from Jordan :)
How are you planning to restore the car? Like as it came from the factory? Or kind of custom with your own touches, fixing and improving things along the way?
The turn signal is on a relay, it's probably defective. Find it and replace it, problem solved. Temp gauge can be replaced with an aftermarket fairly easily.
I guess since you are on an audio forum, you plan to upgrade the stereo system in the car too. So the v-belt setup will have to be replaced in favor of a serpentine belt setup. Well, not necessarily HAVE to be replaced, but it opens up options on a charging system more than with a v-belt.
and the wipers.check for a ground strap/wire going to the wiper motor. i know on some fords if that ground gets messed up the wipers wont stop.......if all else fails try a new ignition/key switch. good luck
SAZ3000D
SAX100.2
  • Who's Online   0 Members, 0 Anonymous, 762 Guests (See full list)
