? on grounds
Im trying to decide where to run my grounds to in the rear of my car. I have a spot i think may work but im not 100% on it so need some help please. this is in my 2012 ford fusion, i have removed my spare tire, i can drill threw that spot and i can access what you see in the pic, it looks solid if it is a good spot to run a few grounds i will sand it down good and clean up before moving foward. If will not work any other suggestions? the second pic is just a continuation of where that metal goes. Thank you ahead of time.
That should be a great ground. Do a ground to the front sections from a solid spot as close to the alt as possible. Also a ground from that front spot to the battery is a good idea.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
Well get your rear ground done.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
  • Who's Online   0 Members, 0 Anonymous, 487 Guests (See full list)
