Mechman Alternators
Fuse Block for 240a S-Series Mechman?
Do I, or do I not need a 250 amp fuse from the positive alt to positive battery cable for my 240a S-Series Mechman Alternator? I spoke with Brian last week about it and he told me that I could, if it gave me peace of mind. I don't want to waste my money and time if I can avoid it, but I also want it done correctly.
I'm confused, as I always see fuse blocks from this wire. Also, other HO Alternator companies do recommend the fuse block on this wire. I don't want to burn up my car or void the warranty, just to get a little more amperage/voltage to my system. Yes, I have run 1/0 wires from the positive alt to battery, alt to negative post on battery, and a 1/0 run from negative post of battery to strut tower bolt that was sanded down to metal (drive a Toyota Camry, best place to ground to frame). So, do I need a 250 amp fuse block on the positive wire? Also, I assume I did the Big 3 upgrade by running the wires as mentioned above. Do I still need to run a 1/0 wire from my negative battery post to my engine block? I assume this was completed as I ran the 1/0 wire from my alternator mounting post to the negative post of my battery. Any suggestions or feedback will be greatly appreciated. I am a noob when it comes to electrical, but not completely green if you know what I mean. I have set up many systems, but none with such an upgraded electrical system that I am about to install. More on batteries later... I want to address alternator first. Thanks!
2013 Toyota Camry SE
240a MechMan HO Alternator
1/0 Welding Flex Cable Big 3
CT Sounds 4000.1D
Kenwood XR400-4 Mid/High Amp
SoundQubed Q4-120 Mid Amp
Infinity Kappa 6.5 components
Kappa 6x9's for rear deck fill (coming out)
(4) 8" PRV 8MB450's
Set of SoundQubed SuperTweets
(2) DSS Ethos 12's D2's @32.5hz (building 4th order enclosure)
(2) SQ HDC3 10's @ 33.5hz (current build, loving them)
Pioneer AVH-X4600BT
100 sq/ft Stinger RoadKill Sound Deadner
120 sq/ft QMat Sound Deadener
(4) Juice Box Black Cherries
Lots and Lots of feet of SHCA wire, along with 50' of Welding 1/0
2 Runs of 1/0 Positive front to back
ToolMaker Everywhere
Meh, I don't see a point. Just don't route the wire stupidly..
This is the only wire I don't have fused..
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Appreciate it hdoore... I drive a lot for my job, sometimes 10 hrs at a time. Didn't want anything overheating, catching fire, you get the point. I have it run the shortest possible route I could find. Do you think I should run one more ground from the negative battery to the engine block? I'm not hearing any whining or anything like that, so I think all my grounds are good. Just wanted to lower resistance anywhere I could. After doing resistance testing on alternator, everything was .01 or .00. All should be good I suppose...
CT Sounds 4000.1D
(4) 8" PRV 8MB450's
Pioneer AVH-X4600BT
Damn, I like that resistance ;) For my car, the ground run I upgraded are engine block to chassis, and chassis to battery.
You already have a run from batt - to engine block though, right? You should be all set :good:
LMFAO so true
:blush:
Thanks for the assurance... Yeah, i was surprised at the resistance as well. I forget which cable exactly, but it was bouncing from .01 to .02. Those were the highest readings though...
CT Sounds 4000.1D
(4) 8" PRV 8MB450's
Pioneer AVH-X4600BT
