alternator whine
k guys so i recently added another 4 channel amp to the car making 2 so what i did was bridged each one at 4 ohms making each now a 150 rms x 2 so i have one up for the front one for the rear speakers. gain matched.
now after adding the 2nd amp i have really bad alternator whine something i have never had before. atm things are kinda just thrown together for tuning and such. what can cause this.
the rcas on the amp are pretty close to the + of a battery thats the only thing i could think of that would cause this. but just in case what other things can
I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
How are your wires routed. Where is iT grounded to?
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
shock tower with 1/0 i dont think its a grounding issue because like i said it wasnt there before
You do realize there I'd another section than general audio right? Every time you post in here I have to move it to another section. Please start posting in the right sections or they will just get deleted. It's a lot easier
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
my bad i didnt know you had to move them i usually try and keep everything where it should be but if its something i feel is urgent ill go to gernal cause ik more people look there.
i ran diff power and ground to where the original amp was before. and still same issue it then grounded my rca for one amp and it got rid of most of it theres still slight whine there. but i didnt have any before so i dont understand even when hooking up the other amp in 4 chan still same . i even unhooked everything and ran from the sub rca same whine. im not sure what could cause this nothing has really changed exept adding that new amp and even now when its unhooked rca wise i still get the whine using diff inputs perhaps it is the amp back feeding threw the deck is that even possible?
  • Who's Online   0 Members, 0 Anonymous, 487 Guests (See full list)
