03 Tahoe, 4 18s, 2 3800s. 158.5 @ 50hz
Hella nice bro, Love it. Like what you have done with everything. Tuned in for more
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
There's still more to come. Trying to sell the kinetik hc16v's and switch to XS. Voltage drop is horrible right now. At idle it charges high 17s, even with it revved to around 2k, it has dropped to 12s even high 11s.
03 tahoe z71
4 death penalty 18s
2 ampere audio 3800s @ .5 each
18v
156.7 @ 35hz
158.5 @ 50hz
Heres how the back came out. Still needs trim panels but itll work for now
03 tahoe z71
4 death penalty 18s
18v
156.7 @ 35hz
158.5 @ 50hz
Mostly sky high wire. Used some leftover kicker hyperflex 8ga for jumpers and speaker wires.
Sky high rcas
03 tahoe z71
4 death penalty 18s
18v
156.7 @ 35hz
158.5 @ 50hz
Hopefully this will help keep things cool.
03 tahoe z71
4 death penalty 18s
18v
156.7 @ 35hz
158.5 @ 50hz
Amps were turned down a good bit here. Couldn't keep the slave amp out of protect with it turned much higher. I think voltage drop had a lot to do with it. At idle I was charging around 18v, and would drop to 12s. These kinetik hc16v's are hurting everything, lol.
http://youtu.be/ql-c4mqUArg
03 tahoe z71
4 death penalty 18s
18v
156.7 @ 35hz
158.5 @ 50hz
I did have the truck metered also. Still with the amps turned down and no testing any frequencies it did a 155.6 @ 35hz and a 157.3 @ 40hz. Used a SMD AMM-1 to see my true power and at 40hz I got 8446w,35hz made just over 9k, and tried it a second time @ 40hz and got 7961w. So I figure around 8k is what I did the 57.3 at.
03 tahoe z71
4 death penalty 18s
18v
156.7 @ 35hz
158.5 @ 50hz
  • 3 months later...
I completely forgot about this thread. Lol. Did some testing after scrapin. Did these numbers. 35hz and 50hz.
03 tahoe z71
4 death penalty 18s
18v
156.7 @ 35hz
158.5 @ 50hz
And since those numbers, ive added an extra run for the 16v, added more sky high 8ga so I can run gain matched instead of strapped. With the amps still strapped and the extra run, it helped my voltage tremendously. Was going from 18-18.5v to 12-13s full tilt. Added the extra run and now full tilt drops from 18-18.5v to mid 16s. Had a problem with one of my amps so its off for repair, but once it gets back ill be gain matching and turning it up. The 158.5 was still turned down. Should be closer to a 160 once all is said and done.
03 tahoe z71
4 death penalty 18s
18v
156.7 @ 35hz
158.5 @ 50hz
