Help to improve my 18"
Running a Fi bl18 on 1500 rms. Re audio ctx 4200.1 amp and a shitty 1 gauge wiring kit. All of my electrical is stock and its in a GMC 05 envoy. MY headlights dim like a bitch and im just trying to make my sub to the best it can possible be. Other than getting a name brand wiring kit, what else can i do
in order from most expensive to least expensive
high output alt.
get HID's.
get a better amp ground
Audio: First thing is build your own box if you didn't already, design it and tune it to what ever you want. Have fun with this haha. then if you are up to it I would deaden your car, this is a lot of work and takes time, but its worth it. If your ok with doing this I would highly suggest doing this.
Power: Upgrade to high output alternator and run good OFC 0 AWG wire first (I would suggest Knukonceptz, or Sky High audio)! On the 0 AWG wire use a 250 amp ANL fuse on the zero gauge. That amp can handle an 2 AWG input, so get a distro block that goes from 0 to 2 AWG wire. On the 2 AWG wire run a 200 amp ANL fuse (only on hot wire). Then second if you still have money go with two more batteries, one is to replace you car battery, the second is just a second battery. Go to XS powers site and check out their battery, they will also recommend batteries for your specific car.
2002 Toyota Corolla
Pioneer DEH-80PRS
Soundqubed Q1-2200d
Soundqubed HDC3.118
Soundqubed Q4-120
Alpine SPR-60
Alpine SPR-60C
his amp has 120 amps of fusing. exact same amount of my audioque 1200. he doesn't need 0 gauge. 4 gauge will be fine.
He should run 0 gauge from his battery to the second battery (well assuming price isn't an issue and he is running a second battery), but yeah in that case 4 gauge will be fine for going to the amp.
P.S. I read audioque as audiopipe at first and got a little scared haha.
2002 Toyota Corolla
Pioneer DEH-80PRS
Soundqubed Q1-2200d
Soundqubed HDC3.118
Soundqubed Q4-120
Alpine SPR-60
Alpine SPR-60C
So with hooking up this second battery will alll the wiring thats under the hood just go to the xs battery in my hatch if I buy it? Srry for lack of knowledge
as to my knowledge you shouldnt mix the battery under hood with a XS battery since the XS is AGM and the one under hood is something different (forgot what its called)
if anything if your trying to be on a budget i would replace the battery under the hood with the biggest XS you can fit :D
2002 Mustang GT Procharged
Procharger P1SC Supercharger, 8psi
Procharger Intercooler, Headers,
Borla Off Road X-Pipe Exhaust, Mass Airflow
Upgraded Fuel Injectors
SCT Flash Chip (Excaliber II), Throttle Body, Lowering Springs, Carbon Fiber Hood
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
Okay thanks
dont take me up on that but thats just what i think not sure if im correct on that but im pretty sure you shouldnt mix them :unsure:
-Front 275/40ZR17
-Rear 315/35ZR17
5.0 Short Shifter
3.55 Gears
  • Who's Online   0 Members, 0 Anonymous, 3225 Guests (See full list)
