Need help with sub box design
I have four 12 inch MTX 5500 square subs. Im doin a blow thru in a Toyota single cab truck. The bed dims. are 57w-16h-74L. The length from the cab to the start of the wheel tubs is 15 inches. I would like to tune it to around 32 htz.
Are you talking about a 4th order bandpass blowthrough? If so you will likely want to tune lower.
Tune lower than 32Hz with a 4th order bandpass? I think maybe you have that backwards. The tuning would likely need to be bigger to control the high end roll off. A 4th order bandpass gets it's low end response from the sealed chamber of the enclosure.
Sparky, are you wanting a straight forward, vented enclosure? Or as stated, are you looking at having a 4th order bandpass?
Yeah CleanSierra, I meant higher. Sorry bout that.
I have seen numerous blow through designs on this forum and I have a question. If you were to do a standard ported blow through would the opening have to be large enough for the subs and port? Similar to sealing off a trunk with subs/port forward?
  • Who's Online   0 Members, 0 Anonymous, 2966 Guests (See full list)
