Would a capacitor work?
you need identical gauge wires for power and ground. and the largest that will fit in the terminals. too small of wires and you'll starve the amp of power and cause it to shut off.
how do you know the sub is wanting more power at X gain? gain isn't a volume knob. its supposed to be set to match the voltage of the preouts on your headunit.
ok. i will be sure to use 4g for ground. and i dont know for sure, but the sub is rated at 1000 watts rms, and is only getting about 400 right now.
Fi Team 18's (4)
Crossfire 16k
Crossfire 400.4 & 800.4
Pioneer AVH-X491bhs
140ah cmax
CES 320's (2)
Well, regardless of what power you guesstimate, get that ground fixed.
Though, I would definitely save up and get some 1/0.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
A cap will not help in this circumstance. Caps do not turn bad or insufficient electrical into good, but enough capacitance can help stabilize voltage in what is already a stout electrical system.
Nobody wants to spend $ to beef up their electrical but good electrical isn't cheap.
Leave your gain down until you get it fixed.
the terminal on the amp will barely fit a 4g wire.
Specs says it can fit 1/0.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
I guess Sonic Electronics lied then.
Though, you're planning on adding a second amplifier so you could use a run of 1/0 to the back, then have a distribution block that goes to the amplifiers.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
  • Who's Online   0 Members, 0 Anonymous, 953 Guests (See full list)
