Overheating Amp
Jesse Dresselhaus
So here's what's going on. I bought this amp (http://www.audiosavings.com/products/2-channel-Car-Amplifier/SONY-XPLOD-1200-WATT-2-CHANNEL-CAR-AUDIO-AMPLIFIER-AMP/XM2002GTRRB.aspx) and a thrift store about a month ago, and two unknown 10" subs in a sealed box. My friend thought they were Alpine's I believe. I wired them like this initially:
It was generally not great. Things varied wildly by genre, and I needed to EQ drastically in order to get things to sound how I liked. Today, I tried wiring it like this:
I thought--why not? Maybe it would work. It did. 10x louder, got rid of the problems between genres, all boominess, and needed almost no EQ. However, shortly into some hard rocking, it cut out, and was quite hot to the touch (not hot enough to burn my hand though). It turned back on right when I restarted my car.
Question--why did it overheat? Isn't it running at a lower load? Was the gain set to high, or was it wired wrong? Is this how I should be wiring it, or is there a way to determine that without knowing the specs of my subs?
Would love some feedback. It sounds great right now :) But don't want to do damage.
For starters it's a sony xplod. It's cheap. Strike one. It's a class a/b - lots of heat. They run warm by design. Strike two
Have you verified your final ohm load with a multi mter?
The difference in sound between the two setups makes me think there is something amiss. On paper, it's the same amount of power either way.
How shortly are we talking about? 5 seconds? 5 minutes? Where is your amp mounted? Does it have ventilation?
Throwing this out there, I am quite un-knowledgeable. I also don't desire to have the best system
I have not verified my final ohm load. How would I do so?
Shortly was about 30 minutes. My amp is mounted on top of my sub, in my trunk. Not a lot of ventilation.
It didn't overheat before the re-wire however. Something happened when it was re-wired.
If you re-wired it make sure you have a good ground. If you have a multi meter that does ohms then connect the positive and negative going into the amp and see what the ohm load is there.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
Not saying strike 1 as in the amp sucks. Understand that I'm not one to overhaul your setup because of a problem. Some members on here will do that, I don't.
Strike - meaning strike against your problem ;)
Do you have a multi meter? There should be an ohms or resistance setting on there. The symbol looks like this: Ω
Set it to that, the lowest value it will go. Then touch the leads together. If it reads 0, you are good to go. If it reads anything else, remember that number.
Unhook your speaker wire from your amp, touch the positive side to the red lead, negative side to the black lead. Note the reading. Remember that number you remembered earlier? Subtract that from the reading you just took. Post it back here
Of note: If you are getting an erratic reading, re-do this test in a quiet place free of drafts
From the sounds of it is that you dont know what the ohm load of your sub coils are so you could be wiring below the amps stable ohm load
06 monte carlo
2 12 rockford p3s
soundstream rubicon 2500
crescendo audio mezzo 6.5
ct sounds 125.4
execution audio and shca wiring
2 xs d3400 on stock alt
IMO, a multimeter should be part of anyone's audio toolbox. It's a very powerful tool to diagnose things and without it, the only other thing we could do is throw money at your problem. Replace this, relocate that, re wire this thing that way, hoping that it will work. With a DMM, we can diagnose and be sure of the problem.
Regardless of where this goes: I'd relocate your amp to somewhere that has lots of air flow. As I said before, class a/b amps run pretty warm by design, and need cooling
A DMM will be on my to-buy list!
My roommate informed me that he believes that my subs are 4-ohms each, in which case my amp would be running at 2-ohms which is 2-ohms less than it is rated to run in, according to the specs.
Bummer. It sounded incredible. I switched it back right now and it was very lack-luster.
I'll confirm that with a DMM later.
  • Who's Online   0 Members, 0 Anonymous, 731 Guests (See full list)
