Jesse Dresselhaus Posted April 6, 2014 Author Report Posted April 6, 2014 I would get 4g going in that amp Would that make it so I can run the amp at a lower ohm-rating than it's rated at?
Jesse Dresselhaus Posted April 9, 2014 Author Report Posted April 9, 2014 Got a reading of roughly 2 ohms. And it shut off again today due to overheating. Thoughts? Is there anything I can do to run this amp at 2 ohms?
SnowDrifter Posted April 10, 2014 Report Posted April 10, 2014 Not really. Any time you run below the rated load of an amp it's a YMMV thing. As I see it your only safe options are: -New subs with the proper coils -New amp that can handle the load -Run two of your current amp at 4 ohms each ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Guest Posted April 10, 2014 Report Posted April 10, 2014 amp requires 4 gauge. anything smaller and you're straining the hell out of it, in which overheating is one of the symptoms. edit: also, what did you use to crimp the lugs? edit 2: kind of surprised you haven't smoked the amp yet at 2 ohms bridged. do what snowdrifter said.
SnowDrifter Posted April 10, 2014 Report Posted April 10, 2014 You could also run the amp at 8 ohms... That's cost effective. But then you lose your bump ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Jesse Dresselhaus Posted April 10, 2014 Author Report Posted April 10, 2014 I'm currently just running one amp in bridged mode. Seems to give me more bump that two unbridged.
jarredondo1999 Posted April 10, 2014 Report Posted April 10, 2014 I'm currently just running one amp in bridged mode. Seems to give me more bump that two unbridged. Per the website, bridged should be at 4 ohms. 500 watts RMS x 1 bridged @ 4 ohms But you are running it at 2 ohms bridge. Reason for it getting hot and turning off.
