hello, i was wondering if the "subwoofer level control" on these headunits (0 to 15DB) is a kind of bass boost? (and you shouldnt use bass boost i've learnt from this forum?)
i have my amp at 40volts at 2OHM(800rms) and i have the bass on -7, treble on +7 and subwoofer on +10.
is that not a good idea or is it not a problem with the alpine HU's? ( i have a type-r btw:) )
my amp is capable of 1114rms, so should i set the gains to that and turn the subwoofer down nearer to 0?
i have noticed a slight smell every now and then, could that be a problem or ?
thanks for any help.
Ben
edit, here is a link to the manual thing on alpine.
and here is 'my' HU
*Alpine Typr-R 12"
*JBL GTO 1200.1 Sub Amp
*Alpine PDX-4.100
*Rockford Fosgate Power 6.5's
*Rockford Fosgate Fanatics 6.5's Both in front doors
*0/1 Guage wiring from front Junction Boxes to 120AH Battery In Boot (battery removed because too small for alternator)
*140 Amp HO Alternator
*Alpine Head Unit
-------------------------------------------------------------------------x------------------------------------------------------------------------------
Subwoofer level control is how much voltage the pre-out for the subwoofer puts out, keep it at +10.
I adjust my amps with it at 10 and if needed I will put it to 15 all does is lower your RCA volts so there is no good or bad its just a controller
For mine, in have the bass at -7 treble at +7 and the sub. at +10. it used to be at bass 0, treb. at 7 and sub 0. The former setting is the loudest. I havent had any problems with it. My amp doesnt even get warm when im beatin it.
1997 S10 EC
Whats in it
106.9 Sq.ft. Hushmat
DB Elec. 250 amp alt.
HC800&HC1400
MLA Module
Alpine 9886
Knukonceptz wires
Clarion EQS746
poopy Alpine door co-ax's
Change IS Coming
