Sealed Off trunk Box
BigManAC
Hey guys, so its the start of spring and that means I can finally seal off my trunk. I have a Fi BL 15 running on a SQ2200. Here is a box that I have designed and I just wanted to know if yall see anything that I need to change or should change. Any advice is appreciated.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- (4) Crescendo PWX 6
- Cadence XA250.2
SUB STAGE:
-Fi Audio BL 15 (Sealed Off)
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
- SkyHigh OFC power/speaker wire
- Big 3 with SkyHigh 0gauge
Build Log: Click Here
Scores: 146.5db @ 29hz Outlaw
If your height is 17" your port would be 15.5" tall, no?
04 Honda Accord LX Sedan
Kenwood Excelon X998
XS Power D3400
XS Power D1200
Singer 275A alternator with factory bypass
64 sqft SecondSkin Damplifier
Build to be decided
:peepwall:
correct. if the top and bottom are single walled, then 17" tall box would make a 15.5" tall slot port.
edit: also, add some bracing. no such thing as too strong a box. even with a double baffle the box may likely still vibrate with no bracing.
Good point haha must have tought one thing me typed another. Okay I'll put some bracing in there.
Also would it make a big difference structurally if I fiberglassed the inside of the box enough for it to be worth it with just one 15?
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
Looked over the design and made some adjustments. Now using two 1'' dowels as bracing (one vertical and one horizontal).
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
You need to figure out bracing displacement and put it in the box labeled bracing. Won't make a big difference but its the right way.
t1500bdcp
2 t2d4 15"
1 t600.4
1 t400.2
1 set p1 tweets
dang i keep forgetting things, thanks man. ill do that now.
2001 Saturn L200
-Sony MEX-BT4100P
FRONT STAGE:
- Cadence XA250.2
SUB STAGE:
-Crescendo BC2k
ELECTRICAL:
- Singer 240A alt
- XS Power D3400
  • Who's Online   0 Members, 0 Anonymous, 2936 Guests (See full list)
