Joe X! Box for two sundown X-15s! please
The dimensions are 20 tall 36 wide and 24 deep.
Need something tuned to around 31hz
Will go into a Suv so i dont know if sub up port back or subs back ports back
powered by an OPTI 4000 at .5 ohm
Thank you in advance Joe!
Question:
Why would you run that amp at half ohm to get 4000 Watts, when you could run it at 1 ohm and get the 2600W? 2600W is right on for two subs rated at 1250W. I'm just curious, that's all.
The voice coil of subs you closer will only be able to do one or the other. If you get 2 subs with D2 coils, you'll be able to run 2 ohm final load or half. If you get D1 or D4 subs, you can run 1 or 4 ohms for your final load.
Not that I don't understand you need space, if you want an efficient box like your previous build, it would take around 20x47x24 and 5" clearance to the tail gate, width can be exchanged for height or depth. You be the judge though, which you liked better, the little one you built from Sundown's site or the larger one you just finished.
  • Who's Online   0 Members, 0 Anonymous, 3225 Guests (See full list)
